ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2007-11-14T22:36:56+01:00https://brainmodular.org/forums/app.php/feed/topic/5422007-11-14T22:36:56+01:002007-11-14T22:36:56+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=3136#p3136 There's not a lot of FM or RM VSTfx (and I'll make a list at home when I've the time; I only have wireless access at cafes hehe) but there's a ton of VCA, VCF, LPF, HPF, etc, etc. with step sequencers, envelope followers, and all sorts of multiband, multioutput splitting...
Plus a giant pile of tube emulations, even with harmonic overtone/partial spline drawing.
Freeware VSTs are pretty much why I not only wanted, but needed, Usine. Then again the rather inexpensive Metallurgy by Ugo, which I'm making patches for today, does much of what the Sherman does, too.
Statistics: Posted by runagate — 14 Nov 2007, 22:36
]]>2007-11-14T14:31:24+01:002007-11-14T14:31:24+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=3132#p3132 Thank you for yr links, i will try this filters soon and let you know what i think.Thanks again!!!!
Statistics: Posted by noise2sine — 14 Nov 2007, 14:31
]]>2007-11-14T02:53:27+01:002007-11-14T02:53:27+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=3127#p3127Tone2 Filterbank3 or Bifilter2 work as mean Sherman emus. Have a very 'hardware filter' sound to me (subjective, yes).
]]>2007-10-08T23:06:04+01:002007-10-08T23:06:04+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2914#p2914Maybe you can give this a try : http://www.funkfish.de/~blankenburg/plu ... ilter.html It is free, and feature-wise, at least, it is quite close to the Sherman vst one. But to be honnest, i think it is only a feature emulation, and not acccurate sound-wise. And i haven't been convinced at all by the Reaktor module.
[Edit : oops, it is a Waldorf Dpole emualtion, and not Sherman FIlterbank... my bad]
]]>2007-09-10T11:40:54+01:002007-09-10T11:40:54+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2656#p2656But I can't solve this bug. I need external help!
]]>2007-09-10T11:35:42+01:002007-09-10T11:35:42+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2655#p2655 any news about that...?
Statistics: Posted by nay-seven — 10 Sep 2007, 12:35
]]>2007-09-03T11:37:20+01:002007-09-03T11:37:20+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2615#p2615Statistics: Posted by bsork — 03 Sep 2007, 12:37
2007-09-03T11:20:25+01:002007-09-03T11:20:25+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2614#p2614Statistics: Posted by noise2sine — 03 Sep 2007, 12:20
]]>2007-08-30T22:43:44+01:002007-08-30T22:43:44+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2611#p2611 There's a fader to glide between series and parallell connection of the filters (series: in>F1> F2> out; parallell: in>F1>out, in>F2>out), and another coupling filter 2's frequency to filter 1's frequency within +/- 4 octaves.
Instead of mailing it to Noise2Sine, I will put it in the add-ons in case anyone else is interested. So far I haven't added any envelope follower or similar, but I guess the Ohmforce emulation will have something like that(?). It's a relatively simple patch, so it shouldn't be too hard to understand. I know I should have added some comments, but I think it's about time I went to bed...
EDIT: There seems to be something wrong with the uploading of add-ons again...
]]>2007-08-30T15:48:19+01:002007-08-30T15:48:19+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2610#p2610Statistics: Posted by Vincent — 30 Aug 2007, 16:48
]]>2007-08-30T12:31:47+01:002007-08-30T12:31:47+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2609#p2609Thanks as well for the Ohmforce direction.So it's super that the bug with ohmforce and Usine is now fixed. thank you again for your fast and clear support.
Statistics: Posted by noise2sine — 30 Aug 2007, 13:31
]]>2007-08-29T18:02:54+01:002007-08-29T18:02:54+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2608#p2608I've made an emulation of Hematohm, I'll post an add on with the next release. (Next week ?)
]]>2007-08-29T12:19:04+01:002007-08-29T12:19:04+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2604#p2604 @Noise2Sine: I don't have much time to spare on this, but I'll see if I can come up with some simple examples within the weekend or so, and I can mail the patches to you.
]]>2007-08-29T12:02:34+01:002007-08-29T12:02:34+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2603#p2603@bsork I really want to try what you explained but i must say i'm quite a newbie so would you mind, if you have time, to build an example so i will be able to see within yr patch and at the same time, following yr explanation.Anyway thanks a lot for patch idea.
Statistics: Posted by noise2sine — 29 Aug 2007, 13:02
@Vincent: You shouldn't by any chance have downloaded a mac version of Frohmage?
I could have do that, but no. Tell me, do you have any Ohm Force plugs running in Usine? If yes, I'll check twice... By chance, these are trial versions...
Statistics: Posted by Vincent — 29 Aug 2007, 12:18
]]>2007-08-28T21:49:28+01:002007-08-28T21:49:28+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2600#p2600 @Noise2Sine: As Vincent has pointed out, devices like the Sherman are amongst the worst to emulate, but from what I can gather from reading about it, I think you could achieve something similar although it would sound different. Try to start with connecting some analysis modules and faders to frequency and Q on filter modules and start messing around to see what happens. I guess it also could be a good idea to try different variations of connecting filters in series and parallell. You could also try to have some feedback loops in there, but beware of your ears and speakers!
Some form of distortion VST inserted here and there will also be good I think. Trying various VST EQs and resonant filters wouldn't hurt either - the Usine filters are relatively neutral and all-purpose in character.
Another thing that you may try (although I haven't got the faintest idea whether the filter bank has anything like it...), is using delays with very short delay times to create comb filtering. Inversing the delay (audio * -1) will create different combing.
Well, I know this is not what you've asked for, but anyway I hope you feel you've gotten some help.
]]>2007-08-28T19:24:41+01:002007-08-28T19:24:41+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2599#p2599I was suggesting FrOhmAge... ...without having testing it. It's VST2, and it seems that Usine does not recognise it. Am I doing something wrong?
Statistics: Posted by Vincent — 28 Aug 2007, 20:24
But remember that, even very very good, Filters and VCO are the worst emulation of hardware you can find...
Usine is not really a builder but a powerful "combinator". It does not make what other already do very well. It's rather done to "combine" the most effective you can find in effective patches.
Statistics: Posted by Vincent — 28 Aug 2007, 16:08
]]>2007-08-28T13:08:10+01:002007-08-28T13:08:10+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2596#p2596I think there is an emulation with Reaktor (?)
Statistics: Posted by noise2sine — 28 Aug 2007, 13:12
]]>BrainModularBrainModular Users Forum2007-11-14T22:36:56+01:00https://brainmodular.org/forums/app.php/feed/topic/5422007-11-14T22:36:56+01:002007-11-14T22:36:56+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=3136#p3136 There's not a lot of FM or RM VSTfx (and I'll make a list at home when I've the time; I only have wireless access at cafes hehe) but there's a ton of VCA, VCF, LPF, HPF, etc, etc. with step sequencers, envelope followers, and all sorts of multiband, multioutput splitting...
]]>2007-09-03T11:20:25+01:002007-09-03T11:20:25+01:00https://brainmodular.org/forums/viewtopic.php?t=542&p=2614#p2614Statistics: Posted by noise2sine — 03 Sep 2007, 12:20
