ArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-05-07T07:53:33+01:00 https://brainmodular.org/forums/app.php/feed/topic/5410 2016-05-07T07:53:33+01:00 2016-05-07T07:53:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=5410&p=35220#p35220 <![CDATA[reverse on midi sampler]]> so you can maybe add this to the suggestions forum ? :)
Statistics: Posted by nay-seven — 07 May 2016, 08:53
2016-05-07T07:44:58+01:00 2016-05-07T07:44:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=5410&p=35219#p35219 <![CDATA[reverse on midi sampler]]> A 2d reversed bank is a good idea, but my banks are very large (about 150 sounds) and evole on each new concert. It would be difficult to manage. May be in HH3 ?
Statistics: Posted by rlgsbt — 07 May 2016, 08:44
2016-05-06T19:08:47+01:00 2016-05-06T19:08:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=5410&p=35218#p35218 <![CDATA[reverse on midi sampler]]> don't know if it can suit your needs , but an idea could be to create a new bank and double each sound
then set each second one to reverse mode
save the bank
Now a simple Midi transform module before the sampler with a switch (0 / 1) on the pitch inlet will do the job ?
Statistics: Posted by nay-seven — 06 May 2016, 20:08
2016-05-06T16:47:40+01:00 2016-05-06T16:47:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=5410&p=35217#p35217 <![CDATA[reverse on midi sampler]]> Is it possible to automate or trigger in real time the "reverse" option for each sound in the new MIDI sampler ? I can edit this option manually in the sound list, but I would like to affect a MIDI learn for all of them in the same sampler.
thanks
Statistics: Posted by rlgsbt — 06 May 2016, 17:47
save the bank
thanks
