ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-05-12T08:32:22+01:00https://brainmodular.org/forums/app.php/feed/topic/54062016-05-12T08:32:22+01:002016-05-12T08:32:22+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35249#p35249 And "find in patch" from the menu also does not work.
Unless there is a patching trick I didn't figure out??
Frustratingly close. Boy do I like having the whole screen for the IB. I guess I will just be turning hide on and off a lot.
Statistics: Posted by woodslanding — 12 May 2016, 09:32
]]>2016-05-12T08:20:14+01:002016-05-12T08:20:14+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35248#p35248 Once you hide the buttons,IB switch stops working, and the button stops working, just like the midi learn on the original menu button did
Darn, I was so excited!!
Statistics: Posted by woodslanding — 12 May 2016, 09:20
]]>2016-05-12T08:11:06+01:002016-05-12T08:11:06+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35247#p35247 First off, you need two buttons, one in the control panel and one in the IB. I made the one in the IB trigger the other one (thru a pass if changed). Although the IB/Patch is a two-way switch, it is not controlled with a switch, but rather with a button that toggles. Not really a problem so far.
The other problem is that when you switch to patching, the grid is automatically opened. So from the switch in the IB I wired a count MSec module running into a passIfChanged into a button into the grid input. This waits for the grid to open, and then the next button press closes it again. I don't see it at all, so it must close before it even has a chance to open.
I like my new control panel, and I'll just put it in the first patch slot of every WKP.
Thanks!!!
Statistics: Posted by woodslanding — 12 May 2016, 09:11
]]>2016-05-12T00:30:38+01:002016-05-12T00:30:38+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35245#p35245 Makes me wish there was some subset of patching that could be global. Like IB background color (which I DON'T like being global....)
Like Devices....
Statistics: Posted by woodslanding — 12 May 2016, 01:30
]]>2016-05-12T00:20:24+01:002016-05-12T00:20:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35243#p35243 But can you still get to patching?? just via 'find in patch'?
I'll check into it....
Statistics: Posted by woodslanding — 12 May 2016, 01:20
Statistics: Posted by nay-seven — 11 May 2016, 09:02
]]>2016-05-11T06:31:33+01:002016-05-11T06:31:33+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35240#p35240Statistics: Posted by woodslanding — 11 May 2016, 07:31
2016-05-11T06:19:55+01:002016-05-11T06:19:55+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35239#p35239 Okay, I tried setting keycommands to open the windows, but the command to hide/show IB (I.e., make it possible to patch) doesn't work when protect is on.
Statistics: Posted by woodslanding — 11 May 2016, 07:19
]]>2016-05-11T06:02:01+01:002016-05-11T06:02:01+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35238#p35238 I just want the screen space to see my wkp on this smaller monitor.
Statistics: Posted by woodslanding — 11 May 2016, 07:02
]]>2016-05-11T05:48:42+01:002016-05-11T05:48:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35237#p35237 And now I have no idea how to unhide the transport. But I never use it so I guess that's okay.
I will try the protect mode.
Statistics: Posted by woodslanding — 11 May 2016, 06:48
]]>2016-05-03T18:56:28+01:002016-05-03T18:56:28+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35204#p35204Or you can use the protect mode ? ( type protect on your keyboard)
Statistics: Posted by nay-seven — 03 May 2016, 19:56
]]>2016-05-03T18:37:38+01:002016-05-03T18:37:38+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35203#p35203 Haven't been able to track it down in the manual wiki.
Thanks, -eric
Statistics: Posted by woodslanding — 03 May 2016, 19:37
]]>BrainModularBrainModular Users Forum2016-05-12T08:32:22+01:00https://brainmodular.org/forums/app.php/feed/topic/54062016-05-12T08:32:22+01:002016-05-12T08:32:22+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35249#p35249 And "find in patch" from the menu also does not work.
Thanks!!!
Like Devices....
]]>2016-05-11T06:19:55+01:002016-05-11T06:19:55+01:00https://brainmodular.org/forums/viewtopic.php?t=5406&p=35239#p35239 Okay, I tried setting keycommands to open the windows, but the command to hide/show IB (I.e., make it possible to patch) doesn't work when protect is on.
Thanks, -eric
