ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-05-23T06:19:55+02:00https://brainmodular.org/forums/app.php/feed/topic/54032016-05-23T06:19:55+02:002016-05-23T06:19:55+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35302#p35302Statistics: Posted by Ariajazz — 23 May 2016, 06:19
2016-05-18T16:21:38+02:002016-05-18T16:21:38+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35282#p35282Usine Stage is a product made in August 2011...
Statistics: Posted by nay-seven — 18 May 2016, 16:21
]]>2016-05-18T05:20:50+02:002016-05-18T05:20:50+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35280#p35280Statistics: Posted by Ariajazz — 18 May 2016, 05:20
]]>2016-04-28T16:39:31+02:002016-04-28T16:39:31+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35190#p35190( you still use Usine 5 or ? )
Statistics: Posted by nay-seven — 28 Apr 2016, 16:39
]]>2016-04-27T04:43:37+02:002016-04-27T04:43:37+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35189#p35189Statistics: Posted by Ariajazz — 27 Apr 2016, 04:43
]]>2016-04-26T03:58:11+02:002016-04-26T03:58:11+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35179#p35179now if you go upper level at parent patch level you can make a new container. back to the subpatch, cliquing container of subpatch and seting it's where option to "parent container" will put this container contening the fader into parent container and so on
]]>2016-04-26T00:06:37+02:002016-04-26T00:06:37+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35178#p35178 "The container is like a panel but it can contain several other display modules or other containers"
I've tried any way I can imagine to add a container within another one without success. How do I do that?
Statistics: Posted by Ariajazz — 26 Apr 2016, 00:06
]]>BrainModularBrainModular Users Forum2016-05-23T06:19:55+02:00https://brainmodular.org/forums/app.php/feed/topic/54032016-05-23T06:19:55+02:002016-05-23T06:19:55+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35302#p35302Statistics: Posted by Ariajazz — 23 May 2016, 06:19
]]>2016-05-18T16:21:38+02:002016-05-18T16:21:38+02:00https://brainmodular.org/forums/viewtopic.php?t=5403&p=35282#p35282Usine Stage is a product made in August 2011...
