here an update patch from where you start, I've add change scale modules to avoid your issues and quantize data also add a send note OFF Download
And here the leap piano (in the Usine browser) adapted to a vsti Download
Statistics: Posted by nay-seven — 21 Apr 2016, 19:37
]]>2016-04-21T18:33:38+02:002016-04-21T18:33:38+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35155#p35155Statistics: Posted by 23fx23 — 21 Apr 2016, 18:33
2016-04-21T18:22:02+02:002016-04-21T18:22:02+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35154#p35154make monophonic. I don't want to buy a leap to midi plugin. The patch just give me ugly sounds .. Any help?
Statistics: Posted by Shintylla — 21 Apr 2016, 18:22
]]>2016-04-20T22:47:07+02:002016-04-20T22:47:07+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35150#p35150 some tips, add a quantize data module before code 1 to not have continues notes, and maybe a MIDI make monophonic module after the create MIDI module to create notes OFF
And yes, create midi patch midi output to vsti midi in
Statistics: Posted by nay-seven — 20 Apr 2016, 22:47
]]>2016-04-20T22:35:57+02:002016-04-20T22:35:57+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35149#p35149Statistics: Posted by Shintylla — 20 Apr 2016, 22:35
]]>2016-04-20T22:34:45+02:002016-04-20T22:34:45+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35148#p35148Statistics: Posted by Shintylla — 20 Apr 2016, 22:34
]]>2016-04-20T21:05:01+02:002016-04-20T21:05:01+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35146#p35146if note, code 1 is the note number, code 2 the velocity If control change, code 1 is control number, code 2 is value
this means on your workspace, you send note 128 with different velocity on canal 2 ?
Statistics: Posted by nay-seven — 20 Apr 2016, 21:05
]]>2016-04-20T20:17:47+02:002016-04-20T20:17:47+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35145#p35145I uploaded a wkp called leapXaxisToMidi. Can you see if something wrong? Many thanks
Statistics: Posted by Shintylla — 20 Apr 2016, 20:17
Statistics: Posted by Shintylla — 20 Apr 2016, 13:30
]]>2016-04-20T13:16:57+02:002016-04-20T13:16:57+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35140#p35140So here i multiply this value by 127 to have a classic 0 to 127 Midi values this value is send to the code 2 of a create MIDI module here the CC number is 10 The has changed module create this MIDI message each time he receive changes
ok, crossed post with sephult
Statistics: Posted by nay-seven — 20 Apr 2016, 13:16
Statistics: Posted by Shintylla — 20 Apr 2016, 12:49
]]>2016-04-20T12:17:41+02:002016-04-20T12:17:41+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35136#p35136 Let me know if you cant find the posts and ill see if I can dig up the patches.
-s
Statistics: Posted by sephult — 20 Apr 2016, 12:17
]]>2016-04-20T07:35:16+02:002016-04-20T07:35:16+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35132#p35132I'd like to create a patch in which I can assign midi parameters to leap motion outs (fingers pos, palm position ecc..) Is there a tutorial/instruction in which is explaned how to commute values from Leap's module to the desired ones (ex.:MIDI; switches; ecc..) Thanks
Statistics: Posted by Shintylla — 20 Apr 2016, 07:35
]]>BrainModularBrainModular Users Forum2016-04-21T21:40:11+02:00https://brainmodular.org/forums/app.php/feed/topic/53952016-04-21T21:40:11+02:002016-04-21T21:40:11+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35157#p35157best support overall!!!!
Statistics: Posted by Shintylla — 21 Apr 2016, 21:40
]]>2016-04-21T18:22:02+02:002016-04-21T18:22:02+02:00https://brainmodular.org/forums/viewtopic.php?t=5395&p=35154#p35154make monophonic. I don't want to buy a leap to midi plugin. The patch just give me ugly sounds .. Any help?
-s
