ArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-03-23T18:52:17+01:00 https://brainmodular.org/forums/app.php/feed/topic/5375 2016-03-23T18:52:17+01:00 2016-03-23T18:52:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=5375&p=35043#p35043 <![CDATA[save or not save ?]]> peparing the chunks, giving to usine and once getting them back on preset change trig internal refresh code (for example if get a matrix cells data array of float, will need to update display once received) but if i recall correctly even not connected inputs params should be saved in preset.
Statistics: Posted by 23fx23 — 23 Mar 2016, 18:52
2016-03-23T14:58:58+01:00 2016-03-23T14:58:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=5375&p=35039#p35039 <![CDATA[save or not save ?]]>
do you think it is mandatory to have all the parameters possibly saved ? as the inputs will be connected to faders and so forth anyway and be saved.
Statistics: Posted by oli_lab — 23 Mar 2016, 14:58
2016-03-23T14:48:12+01:00 2016-03-23T14:48:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=5375&p=35038#p35038 <![CDATA[save or not save ?]]> there are exemple in the sdk matrix if i recall correctly
Statistics: Posted by 23fx23 — 23 Mar 2016, 14:48
2016-03-23T11:54:35+01:00 2016-03-23T11:54:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=5375&p=35036#p35036 <![CDATA[save or not save ?]]>
is there something to implement ?
thanx
Statistics: Posted by oli_lab — 23 Mar 2016, 11:54
thanx
