ArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-08-21T08:27:45+01:00 https://brainmodular.org/forums/app.php/feed/topic/537 2007-08-21T08:27:45+01:00 2007-08-21T08:27:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=537&p=2568#p2568 <![CDATA[Sampler and some suggestions]]> thanks for your feedback. I do my best to implement all suggestions.
An inlet and an outlet with the full path file name could be interesting to automate sampler file between several instance: sampler 1 record, then save, then send the recording file to another sampler.
I'll probably add a lot of new features like that. strings, list, fft, etc.
Be patient.
More "aux send bus" ( 4 in total? Mmmm)
Remember that everything has a cost. Buses take a lot of CPU because they are in 8.0 surround mode. The aux buses are a good solution if you need more aux.
Anyway, I'll increase (slowly...) the number of aux.
"Additional audio output module" : possibility to send the signal in tracks, and/or aux bus. Not only to output 1,2,3,...
you can do that with buses?
Insert patches in the mixers.
soon!!
Statistics: Posted by senso — 21 Aug 2007, 09:27
2007-08-20T20:37:01+01:00 2007-08-20T20:37:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=537&p=2566#p2566 <![CDATA[Sampler and some suggestions]]>
you're possibly aware of the fact tat you can create as many virtual sends as you want using the send/get busses? Not as easy to use as extra auxes, I know.
I don't think that the "deleted" wires make any difference CPU-wise, but you can do as Vincent suggests. A little workaround if you don't want to turn tracks on or off in grid mode is to create an empty dummy-patch when needed.
For complex calculations involving lots of data - especially in arrays - using a script can sometimes be effective. The Usine patches are of course calculated for every ASIO block - the interval dependent on the block size and the sample rate: 1000 / sample rate * block size = milliseconds between each execution. Using a script you can "thin" the executions to each nth block for example, which should be okay as long as the timing isn't too critical. A good example (well, I think so anyway) is the "XY morph example" add-on I created.
Statistics: Posted by bsork — 20 Aug 2007, 21:37
2007-08-20T16:17:17+01:00 2007-08-20T16:17:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=537&p=2564#p2564 <![CDATA[Sampler and some suggestions]]>
-I'm not sure of this, but usine don't seems to put some modules in sleep mode.
Hi Moody33
Well, I'm answering but I'm not sure I understand the "sleeping modules"... That could anyway be a good title!
You can activate/deactivate full patches with an Interface Control/Patch Active Module.
Is this an answer?
Other suggestion seem to be good!
Statistics: Posted by Vincent — 20 Aug 2007, 17:17
2007-08-20T12:46:59+01:00 2007-08-20T12:46:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=537&p=2563#p2563 <![CDATA[Sampler and some suggestions]]>
- An inlet and an outlet with the full path file name could be interesting to automate sampler file between several instance: sampler 1 record, then save, then send the recording file to another sampler.
-I'm not sure of this, but usine don't seems to put some modules in sleep mode. Could be intersting that modules that don't receive/don't send any value change entering in " sleep mode ". Don't know if it's possible.
When you say in the manual " as if the wire was delete" about the pass/stop modules, does it means that it consume less cpu?
-Audio :
- More "aux send bus" ( 4 in total? Mmmm)
-"Additional audio output module" : possibility to send the signal in tracks, and/or aux bus. Not only to output 1,2,3,...
- Insert patches in the mixers.
-Midi pianoroll: Ok, ok.......I know, you need to sleep.
-Think I've found a bug: when recording in overdub mode, the waveform display is not update. Only the first pass is show on the waveform display.
Thanks you for your great work.
Statistics: Posted by moody33 — 20 Aug 2007, 13:46
Be patient.
soon!!
Hi Moody33
Is this an answer?
-Audio :
