ArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-03-03T20:58:04+01:00https://brainmodular.org/forums/app.php/feed/topic/53412016-03-03T20:58:04+01:002016-03-03T20:58:04+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34895#p34895sonically, it is even more interesting !:)
Statistics: Posted by oli_lab — 03 Mar 2016, 20:58
]]>2016-03-02T22:36:03+01:002016-03-02T22:36:03+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34887#p34887Statistics: Posted by oli_lab — 02 Mar 2016, 22:36
2016-03-02T17:07:50+01:002016-03-02T17:07:50+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34885#p34885 I think the "pull out a wire" function only uses the information in the ParamInfo data, so it does not know about the sdkSetEvtSize() on the event. Anyway arrays are variable size - the array get and set modules ask you how many parameters / faders you want since it does not know.
Regarding the min/max value - I would have thought that should be used with the "pull out a wire" function, but it might depend what option you are selected on the "pull out a wire" menu.
Simon.
Statistics: Posted by sm_jamieson — 02 Mar 2016, 17:07
]]>2016-03-02T00:41:24+01:002016-03-02T00:41:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34879#p34879 in my last module, I use an array input that is supposed to take 0 to 255 integers in a table that has a size of 256.
as well as setting the size of the event in the initialisation : sdkSetEvtSize(shape, 256);
But, when I pull a wire out of the array input, I get an array of size 16 with 0 to 1 integers...
thanx for your help
Statistics: Posted by oli_lab — 02 Mar 2016, 00:41
]]>BrainModularBrainModular Users Forum2016-03-03T20:58:04+01:00https://brainmodular.org/forums/app.php/feed/topic/53412016-03-03T20:58:04+01:002016-03-03T20:58:04+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34895#p34895sonically, it is even more interesting !:)
]]>2016-03-02T17:07:50+01:002016-03-02T17:07:50+01:00https://brainmodular.org/forums/viewtopic.php?t=5341&p=34885#p34885 I think the "pull out a wire" function only uses the information in the ParamInfo data, so it does not know about the sdkSetEvtSize() on the event. Anyway arrays are variable size - the array get and set modules ask you how many parameters / faders you want since it does not know.
Simon.
