ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-02-05T10:03:28+01:00 https://brainmodular.org/forums/app.php/feed/topic/5286 2016-02-05T10:03:28+01:00 2016-02-05T10:03:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34645#p34645 <![CDATA[Butterworth HPF and LPF]]>
try to recreate the module
I may have to protect it better, but usually is detrimental to crazyness.
can you send me your .pat ?
olilab101[at]gmail.com
Statistics: Posted by oli_lab — 05 Feb 2016, 10:03
2016-02-05T05:08:04+01:00 2016-02-05T05:08:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34644#p34644 <![CDATA[Butterworth HPF and LPF]]>
I tried to drop in a patch of mine and there is input but no output audio, and the patch that was working.... once I duplicated the filter and tried to wire...the second one does not want to output although the first is working.
I think there be a usine bug popping up, let me know if you are having the same issues
-s
Statistics: Posted by sephult — 05 Feb 2016, 05:08
2016-02-05T05:04:25+01:00 2016-02-05T05:04:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34643#p34643 <![CDATA[Butterworth HPF and LPF]]>
Im blasting my ears and enjoying :)
It's awesome!
I love the feedback topology, the bit mangler is wicked :) I
makes this really quantized bass sound at low cutoff, love the bleed through of the bending as well.
I am really glad you added the FM port in there as well. I just started to try and do some FM stuff in my synths and it's great to have in the filter for that driven sound!
Definitely look forward to implementing in all my patches, I can get some nice drive sounds out of it where other places I am having to add bunches of EQ and high gain modules.
I am also appreciative of having the multiple filters available and the different pole ranges
-s
Statistics: Posted by sephult — 05 Feb 2016, 05:04
2016-02-05T01:09:55+01:00 2016-02-05T01:09:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34641#p34641 <![CDATA[Butterworth HPF and LPF]]>
it's a 4 pole ladder filter with many options.
you can choose different feedback loop for resonance.
whatch your ears as nothing is really normalized...
http://www.sensomusic.com/forums/upload ... esting.zip
Statistics: Posted by oli_lab — 05 Feb 2016, 01:09
2016-02-02T13:04:56+01:00 2016-02-02T13:04:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34617#p34617 <![CDATA[Butterworth HPF and LPF]]>
Very smooth, great to have some additional to add to my synthesizers.
Love the FM addition as well!!!
-s
Statistics: Posted by sephult — 02 Feb 2016, 13:04
2016-02-02T12:59:23+01:00 2016-02-02T12:59:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34616#p34616 <![CDATA[Butterworth HPF and LPF]]> I am having problems trying to locate these.
I was able to download from the add-ons webpage, but from the internal browser update they do not show up for me.
-s
Statistics: Posted by sephult — 02 Feb 2016, 12:59
2016-02-02T01:13:29+01:00 2016-02-02T01:13:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34610#p34610 <![CDATA[Butterworth HPF and LPF]]> Statistics: Posted by oli_lab — 02 Feb 2016, 01:13
2016-02-01T20:31:04+01:00 2016-02-01T20:31:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34608#p34608 <![CDATA[Butterworth HPF and LPF]]>
I cannot wait to try out!
-s
Statistics: Posted by sephult — 01 Feb 2016, 20:31
2016-02-01T19:12:51+01:00 2016-02-01T19:12:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34606#p34606 <![CDATA[Butterworth HPF and LPF]]> that will be fixed very soon.
more on the way....
Statistics: Posted by oli_lab — 01 Feb 2016, 19:12
2016-01-31T17:45:28+01:00 2016-01-31T17:45:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34598#p34598 <![CDATA[Butterworth HPF and LPF]]>
Statistics: Posted by oli_lab — 31 Jan 2016, 17:45
2016-01-31T00:17:16+01:00 2016-01-31T00:17:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=5286&p=34594#p34594 <![CDATA[Butterworth HPF and LPF]]> Two different sounding filters for Usine !
thanx for your feedback
Statistics: Posted by oli_lab — 31 Jan 2016, 00:17
-s
It's awesome!
-s
-s
-s
-s
more on the way....
