ArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-01-22T15:25:43+01:00https://brainmodular.org/forums/app.php/feed/topic/52532016-01-22T15:25:43+01:002016-01-22T15:25:43+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34569#p34569Suggestion: Settings in "user" tabs should expose the settings in module extended mode. Ideally each tab could be set to expose its settings or not. Thanks, Simon.
Statistics: Posted by sm_jamieson — 22 Jan 2016, 15:25
]]>2016-01-21T14:20:24+01:002016-01-21T14:20:24+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34557#p34557Statistics: Posted by sm_jamieson — 21 Jan 2016, 14:20
2016-01-20T17:30:52+01:002016-01-20T17:30:52+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34553#p34553Good news for second. Was a good exercice for me trying to save/recall from text files and currenly working not bad but i was affraid not safe dealing with autorisations and files locations if sharing.
@simon 'tabs' just refers to the cool ability we have to label a place where a setting should be visible when using the 'onCreateSettings' bolean, int, float ect. the first string in those command lines will make them appear in a same labeled 'tab' when right clicking on module. making different names creates different tabs.
Statistics: Posted by sm_jamieson — 20 Jan 2016, 13:11
]]>2016-01-07T21:08:28+01:002016-01-07T21:08:28+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34477#p34477I think that it's more "risky" to change this behavior for backward compatibility reason. I'll take a look.
for the second suggestion, this option is already implemented in Usine but not exposed in the SDK. I think it is possible to implement it.
]]>2015-12-31T10:13:47+01:002015-12-31T10:13:47+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34410#p34410 One little thing i could observe that could be "risky" it seems is that the recall of variables seems linked to the label "quoted strings". if same name is used on several places it could lead to problems. for exemple i made a "listBox" tab where i had a "Show Header" bool setting and it was affecting the ability to show header of the module itself, on creation, the field disapeared on the module usual layout eye tab "show header" setting. Or I made several tabs "fader", "encoder" ect tabs with their own variables but same labeled "encoder speed" and it seems variables could add together on init or interfere somehow. We can easely choose unique label, but felt it would maybe more "secured" to have this dealed internally, suppose with a unique id or tag added, maybe linked to tab name or something if not too complex..
One other idea would be to make individual per tab snapshots store/recall possible. Did a custom function for this but i got to manually redefine and store/recall a vector pair of pointer adress and datatype wich i felt could be done more easily "internally" as we already provide all infos in onCreateSetting, but maybe it's too much specific.. (like recall a 'layout tab" preset without recalling ie a fuctionality behaviour tab). just an idea..
]]>BrainModularBrainModular Users Forum2016-01-22T15:25:43+01:00https://brainmodular.org/forums/app.php/feed/topic/52532016-01-22T15:25:43+01:002016-01-22T15:25:43+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34569#p34569Suggestion: Settings in "user" tabs should expose the settings in module extended mode. Ideally each tab could be set to expose its settings or not. Thanks, Simon.
]]>2016-01-20T17:30:52+01:002016-01-20T17:30:52+01:00https://brainmodular.org/forums/viewtopic.php?t=5253&p=34553#p34553Good news for second. Was a good exercice for me trying to save/recall from text files and currenly working not bad but i was affraid not safe dealing with autorisations and files locations if sharing.
