ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-02-17T19:42:12+02:00 https://brainmodular.org/forums/app.php/feed/topic/5252 2016-02-17T19:42:12+02:00 2016-02-17T19:42:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34758#p34758 <![CDATA[any help with wii remote set up]]>
i see you still use an old version of Usine, have you try with the latest version ?
you run Usine after the connection is established with blue soleil ?
I can confirm, yes. Just downloaded latest version and run Usine after connection has been established.
My wiii is too much "original" :)
Statistics: Posted by r.erorr — 17 Feb 2016, 18:42
2016-02-17T09:31:10+02:00 2016-02-17T09:31:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34756#p34756 <![CDATA[any help with wii remote set up]]> you run Usine after the connection is established with blue soleil ?
Statistics: Posted by nay-seven — 17 Feb 2016, 08:31
2016-02-17T03:29:26+02:00 2016-02-17T03:29:26+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34755#p34755 <![CDATA[any help with wii remote set up]]> https://www.youtube.com/watch?v=zjmvOcV ... e=youtu.be
Statistics: Posted by r.erorr — 17 Feb 2016, 02:29
2016-02-16T14:26:41+02:00 2016-02-16T14:26:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34750#p34750 <![CDATA[any help with wii remote set up]]>
Only one solution to use wiimote on PC it is :
1°) A Wiimote by Nintendo
2°) Use : http://www.bluesoleil.com/ for connection.
On Mac Os you need :
2°) Install OSCulator (The free version) Just for pass out the PIN code step.
Statistics: Posted by multiphone — 16 Feb 2016, 13:26
2016-02-16T13:32:14+02:00 2016-02-16T13:32:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34749#p34749 <![CDATA[any help with wii remote set up]]>
@r.error: really strange, have you try other softwares ?
example: Osculator
On PC:
I tried with two different Bluetooth adapters "Trust" seems more stable, but time to time losses connection anyway. "Asus" doesn't connect at all with my wii. (tested with game emulators)
MAC:
Connected without problems, but I haven't tested any application. except Usine that wont work for me
No I haven't tried with OSCulator jet. Need to borrow MAC again
Do you know anything for windows to test?
Statistics: Posted by r.erorr — 16 Feb 2016, 12:32
2016-02-16T12:53:10+02:00 2016-02-16T12:53:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34748#p34748 <![CDATA[any help with wii remote set up]]> example: Osculator
Statistics: Posted by nay-seven — 16 Feb 2016, 11:53
2016-02-16T11:41:52+02:00 2016-02-16T11:41:52+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34746#p34746 <![CDATA[any help with wii remote set up]]>
Didn't realise you could use a wii mote as a controller, I'm intrigued by the potential and will definitely look into this!
Unfortunately I haven't got it work. Probably there is new generation wii motion plus that are not compatible with Hollyhock. I have already tried on win8.1 win10 and Yosemite[MacBook Air] with no luck.
Statistics: Posted by r.erorr — 16 Feb 2016, 10:41
2016-02-15T22:34:12+02:00 2016-02-15T22:34:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34741#p34741 <![CDATA[any help with wii remote set up]]> Statistics: Posted by Andrulianblog — 15 Feb 2016, 21:34
2016-01-04T15:20:57+02:00 2016-01-04T15:20:57+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34448#p34448 <![CDATA[any help with wii remote set up]]> Yes I remember that code 0000 , but now it just connects and disconnects without asking any code.
Statistics: Posted by r.erorr — 04 Jan 2016, 14:20
2016-01-04T13:39:58+02:00 2016-01-04T13:39:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34447#p34447 <![CDATA[any help with wii remote set up]]> you can see the option button in the bluetooth panel when you try to connect the first time, the 0000 is the connection code by default
Statistics: Posted by nay-seven — 04 Jan 2016, 12:39
2016-01-04T13:30:07+02:00 2016-01-04T13:30:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34446#p34446 <![CDATA[any help with wii remote set up]]>
Whera are those options you are talking about? I'm not mac user, just tested on my friends machine
Statistics: Posted by r.erorr — 04 Jan 2016, 12:30
2016-01-04T12:36:21+02:00 2016-01-04T12:36:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34445#p34445 <![CDATA[any help with wii remote set up]]> Have you try to use the red button to sync ?
code=0000 in options ?
Statistics: Posted by nay-seven — 04 Jan 2016, 11:36
2016-01-04T12:06:44+02:00 2016-01-04T12:06:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34444#p34444 <![CDATA[any help with wii remote set up]]> Do I need any special drivers on Mac?
Statistics: Posted by r.erorr — 04 Jan 2016, 11:06
2015-12-31T04:36:17+02:00 2015-12-31T04:36:17+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34409#p34409 <![CDATA[any help with wii remote set up]]> I'll try again and see if I can give a hand on figuring.
Statistics: Posted by sephult — 31 Dec 2015, 03:36
2015-12-31T01:26:47+02:00 2015-12-31T01:26:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=5252&p=34408#p34408 <![CDATA[any help with wii remote set up]]> this is hardly patching question, so I decide to ask it here. Can you help to set up Wii remote?
1. I have "trust" bluetooth adapter
2. I have already tried to set up on two different win 8 machines
3. . . . with and without Bluesoleil drivers
4. in booth cases conection is succesfull
5. . . . But I cant set up GlovePIE nor see any change on wiimote module
6. I also tried on Usine v.5 and Hollyhock II
Statistics: Posted by r.erorr — 31 Dec 2015, 00:26
example: Osculator
On PC:
MAC:
