ArrayArrayArrayArray
BrainModularBrainModular Users Forum2015-12-15T13:29:53+02:00https://brainmodular.org/forums/app.php/feed/topic/52282015-12-15T13:29:53+02:002015-12-15T13:29:53+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34299#p34299Statistics: Posted by sephult — 15 Dec 2015, 12:29
2015-12-15T09:59:49+02:002015-12-15T09:59:49+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34296#p34296I thought about cleaning my windows USB history. I'll give it a try.
Statistics: Posted by La Tenaille — 15 Dec 2015, 08:59
]]>2015-12-15T03:08:11+02:002015-12-15T03:08:11+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34295#p34295Subsequent sessions will be fine, but will happen every once and awhile. I assume it's a USB ID thing.
-s
Statistics: Posted by sephult — 15 Dec 2015, 02:08
]]>2015-12-14T23:50:23+02:002015-12-14T23:50:23+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34294#p34294Have you experimented detection troubles with behringer BCF or BCR ? I have both units, and sometimes MIDI doesn't work properly. Generally just one unit, and just one way (MIDI in or out). I have to close Usine, switch off and on the unit... sometimes it's not enough. Once the dection is right everything runs fine. I'd really like to find a way to avoid this. Thanks
Statistics: Posted by La Tenaille — 14 Dec 2015, 22:50
]]>BrainModularBrainModular Users Forum2015-12-15T13:29:53+02:00https://brainmodular.org/forums/app.php/feed/topic/52282015-12-15T13:29:53+02:002015-12-15T13:29:53+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34299#p34299Statistics: Posted by sephult — 15 Dec 2015, 12:29
]]>2015-12-15T09:59:49+02:002015-12-15T09:59:49+02:00https://brainmodular.org/forums/viewtopic.php?t=5228&p=34296#p34296I thought about cleaning my windows USB history. I'll give it a try.
-s
