ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2016-01-07T21:34:47+01:00https://brainmodular.org/forums/app.php/feed/topic/52172016-01-07T21:34:47+01:002016-01-07T21:34:47+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34483#p34483Statistics: Posted by senso — 07 Jan 2016, 21:34
2015-12-17T20:42:13+01:002015-12-17T20:42:13+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34335#p34335Statistics: Posted by senso — 17 Dec 2015, 20:42
]]>2015-12-11T15:18:51+01:002015-12-11T15:18:51+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34277#p34277
i would love as well but i don't think it's actually possible, have to make text input 'real' parameter, not possible to set directly in tabs. it seems possible however to trig an iml message with a query asking user to input text then will set the textfield input of module to get back in the code but module got to have a header name set for iml to access it and bit more complex solution.to set up. so +1 if implementation would be possible^^
I'm sure this feature could be added at some stage. I mean, you have all the data types but a string, and you need a string for many custom menus.
Using a real parameter would be OK if you could choose where it will be displayed, so it could be displayed next to your custom settings lines. I have avoided IML as I don't think it is the way to go - using module names etc is asking for problems. I would probably use sdkAddSettingLineBoolean to trigger some type of popup window from the module with a custom string input field. Even create a non-usine window, i.e. using Juce directly - the code for the plugin wrapper shows you how to do this type of thing !
Simon.
Statistics: Posted by sm_jamieson — 11 Dec 2015, 15:18
]]>2015-12-11T04:23:09+01:002015-12-11T04:23:09+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34274#p34274Statistics: Posted by 23fx23 — 11 Dec 2015, 04:23
]]>2015-12-10T18:05:29+01:002015-12-10T18:05:29+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34269#p34269 sdkAddSettingLineCaption sdkAddSettingLineColor sdkAddSettingLineBoolean sdkAddSettingLineInteger sdkAddSettingLineSingle sdkAddSettingLineCombobox
Is there a function to allow a text string setting ? Such as sdkAddSettingLineString ?
I do love Usine, but I find a lot of times I can almost do what I want, but not quite ! It is very frustrating.
Thanks, Simon.
Statistics: Posted by sm_jamieson — 10 Dec 2015, 18:05
]]>BrainModularBrainModular Users Forum2016-01-07T21:34:47+01:00https://brainmodular.org/forums/app.php/feed/topic/52172016-01-07T21:34:47+01:002016-01-07T21:34:47+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34483#p34483Statistics: Posted by senso — 07 Jan 2016, 21:34
]]>2015-12-17T20:42:13+01:002015-12-17T20:42:13+01:00https://brainmodular.org/forums/viewtopic.php?t=5217&p=34335#p34335Statistics: Posted by senso — 17 Dec 2015, 20:42
Simon.
Thanks, Simon.
