ArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-11-15T13:29:46+02:00 https://brainmodular.org/forums/app.php/feed/topic/5183 2015-11-15T13:29:46+02:00 2015-11-15T13:29:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=5183&p=34122#p34122 <![CDATA[erratic comportement with osc]]>
Statistics: Posted by oli_lab — 15 Nov 2015, 12:29
2015-11-15T11:54:44+02:00 2015-11-15T11:54:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=5183&p=34121#p34121 <![CDATA[erratic comportement with osc]]>
it seems you create a loop ?
you receive /spherereceive/x that you send to /spheresend/x ( btw, X in broadcast Y not ? )
and in the preview sub patch you receive this same /spheresend/x that you send again to /spherereceive/x ?
Statistics: Posted by nay-seven — 15 Nov 2015, 10:54
2015-11-14T09:56:29+02:00 2015-11-14T09:56:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=5183&p=34118#p34118 <![CDATA[erratic comportement with osc]]> I opened your wkp but could not see any OSC related module...
what I usually do is to take care of all the OSC messages in a device (one for input and one for outputs) and then send the data via data bus.
Statistics: Posted by oli_lab — 14 Nov 2015, 08:56
2015-11-14T04:01:30+02:00 2015-11-14T04:01:30+02:00 https://brainmodular.org/forums/viewtopic.php?t=5183&p=34115#p34115 <![CDATA[erratic comportement with osc]]> i made a little workspace that use osc and that worked well.
I saved it and re open. Now i make saturate the cpu and dosen't respond :
here it is :
http://www.sensomusic.org/forums/upload ... pheres.wkp
If someone could look at this...
Statistics: Posted by joffo78 — 14 Nov 2015, 03:01
here it is :
