ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2015-11-10T01:01:42+01:00https://brainmodular.org/forums/app.php/feed/topic/51712015-11-10T01:01:42+01:002015-11-10T01:01:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34085#p34085 (when I map a parameter to an external midi controller and then automate it in the grid, weird things can happen when copying and pasting the grid section. The parameter being automated doubles itself on the new pasted section appearing twice, as if overlaying on itself. Ill investigate more fully after my next performance, just focussing on getting everything stable for the moment)
other grid desires,
Being able to individually name rack sections
copy and paste curves between racks, i.e. copy a curve from rack One and paste on to a selected parameter on rack Two
Grid override toggle switch, per rack/ grid section disabling the curves so manual control using external controllers is possible mid performance. If I have to lower the volume of a track mid set its not possible if the level is automated. My workaround is to have short pre sections that set up the automation parameters, followed by a section that has no automation so I can alter if needed.
multiple selection of sections
Statistics: Posted by Pianoscope — 10 Nov 2015, 01:01
]]>2015-11-09T14:56:57+01:002015-11-09T14:56:57+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34081#p34081will be solved in the next release
Statistics: Posted by nay-seven — 09 Nov 2015, 14:56
]]>2015-11-09T11:15:33+01:002015-11-09T11:15:33+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34077#p34077 Heres a photo that explains it. I
Rack 6 is sending to the others. I am automating each send in the grid, as you can see when I want to edit later, I don't know which send the curve corresponds to.
Statistics: Posted by Pianoscope — 09 Nov 2015, 11:15
]]>2015-11-08T17:15:29+01:002015-11-08T17:15:29+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34068#p34068Statistics: Posted by nay-seven — 08 Nov 2015, 17:15
2015-11-08T14:26:57+01:002015-11-08T14:26:57+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34064#p34064I have 9 sends to automate.
The problem is when I click on the rack in the grid, the inspector just shows me a list of "gain's" that I have chosen to automate terms.ie:
gain gain gain gain gain gain
etc.
So I have no idea which curve goes with what send.
It should read
Echo Gain Delay Gain Reverb Gain FX1 gain etc
its making it really hard work to know whats going on, and edit the curves
Statistics: Posted by Pianoscope — 08 Nov 2015, 14:26
]]>BrainModularBrainModular Users Forum2015-11-10T01:01:42+01:00https://brainmodular.org/forums/app.php/feed/topic/51712015-11-10T01:01:42+01:002015-11-10T01:01:42+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34085#p34085 (when I map a parameter to an external midi controller and then automate it in the grid, weird things can happen when copying and pasting the grid section. The parameter being automated doubles itself on the new pasted section appearing twice, as if overlaying on itself. Ill investigate more fully after my next performance, just focussing on getting everything stable for the moment)
other grid desires,
]]>2015-11-08T14:26:57+01:002015-11-08T14:26:57+01:00https://brainmodular.org/forums/viewtopic.php?t=5171&p=34064#p34064I have 9 sends to automate.
etc.
It should read
