ArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-10-10T10:38:03+01:00 https://brainmodular.org/forums/app.php/feed/topic/5120 2015-10-10T10:38:03+01:00 2015-10-10T10:38:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=5120&p=33850#p33850 <![CDATA[Ability to drive position of sampler via another]]> I made an example http://www.sensomusic.org/forums/upload ... 0senso.pat
Statistics: Posted by senso — 10 Oct 2015, 11:38
2015-10-04T15:21:47+01:00 2015-10-04T15:21:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=5120&p=33813#p33813 <![CDATA[Ability to drive position of sampler via another]]>
I will have to try that soon! Genius!
I didn't even think about using the Grain Sampler speed when I was doing this, thanks for the help.
-s
Statistics: Posted by sephult — 04 Oct 2015, 16:21
2015-10-04T13:47:06+01:00 2015-10-04T13:47:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=5120&p=33812#p33812 <![CDATA[Ability to drive position of sampler via another]]> use the position of your master (M) and the position of the slave (S)
then do S - M = error
with a curve mapper, transfor this error in pitch
this pitch will drive the slave that will adapt its speed so to get in sync with the marter !
Statistics: Posted by oli_lab — 04 Oct 2015, 14:47
2015-10-03T16:33:17+01:00 2015-10-03T16:33:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=5120&p=33806#p33806 <![CDATA[Ability to drive position of sampler via another]]> I think it would be invaluable to have pos control. This way secondary samplers could be used as duplicate buffers.
An example would be to modify the position of a sample randomly (releasing flow from the primary), when done the two samplers would snap back in position where the primary is driving the position of the secondary. Almost a Sync to Primary sampler position as it would be.
-s
Statistics: Posted by sephult — 03 Oct 2015, 17:33
-s
-s
