Statistics: Posted by fdonato — 03 Oct 2015, 18:43
]]>2015-10-03T17:12:07+01:002015-10-03T17:12:07+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33809#p33809 I just cant seem to get a high audible Click like it was a buffer problem.
I am currently using my Focusrite 18i8 and Windows 10. 64-bit Sorry I can't reproduce here.
Statistics: Posted by sephult — 03 Oct 2015, 18:12
]]>2015-10-03T16:49:47+01:002015-10-03T16:49:47+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33808#p33808And to be exhaustiv, Windows 10. Well I think I'm going to find another way to build my patch. Thanks anyway.
Statistics: Posted by fdonato — 03 Oct 2015, 17:49
Statistics: Posted by sephult — 03 Oct 2015, 17:38
]]>2015-10-03T15:44:17+01:002015-10-03T15:44:17+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33805#p33805the link to the patch. Yes it's a very basic use of the MIDI Sampler module with just controls to change poly, pitch and gain. I've tried with another instance in an empty workspace with only MIDI In and Audio Out modules, with short or long samples of mine but also some bass, voice or synth samples provided by Usine. Always clicking at Note Off. I've change the block size, 64 or 128 or 256 = the same. Disk streaming or RAM loaded = the same. One point is that using a standard sample player does not produce any click on NoteOff ??? Version of HH2 is 2.0 081 NoteBook Asus I7 4700HQ
Statistics: Posted by fdonato — 03 Oct 2015, 16:44
]]>2015-10-03T15:09:56+01:002015-10-03T15:09:56+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33804#p33804 -> Just a basic midi sampler here, tried changing poly, pitch, and using long samples and no clicks. Maybe check your bloc size? Increasing may help? Does it do it with only 1 sample loaded? Does it happen on every release of just one note played?
-S
Statistics: Posted by sephult — 03 Oct 2015, 16:09
]]>2015-10-03T11:14:59+01:002015-10-03T11:14:59+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33802#p33802Statistics: Posted by fdonato — 03 Oct 2015, 12:14
Statistics: Posted by fdonato — 01 Oct 2015, 16:02
]]>2015-10-01T09:30:59+01:002015-10-01T09:30:59+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33780#p33780have you this issue with all your samples ?
Statistics: Posted by nay-seven — 01 Oct 2015, 10:30
]]>2015-09-22T19:59:00+01:002015-09-22T19:59:00+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33750#p33750I'm using a Midi Sampler module in my workspace and play it with a Quneo. Everything's fine except that every Note Off sent by the Quneo generates a very audible click on the sound it has triggered. Of course it's possible to de-activate Note Off in the Midi Sampler parameters but doing so cancels the use of the release parameter : the audio file is played until it's end or the loop end marker. Anyone with the same problem and may be with a solution ?
F.
Statistics: Posted by fdonato — 22 Sep 2015, 20:59
]]>BrainModularBrainModular Users Forum2015-10-03T17:43:23+01:00https://brainmodular.org/forums/app.php/feed/topic/51122015-10-03T17:43:23+01:002015-10-03T17:43:23+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33810#p33810Anyway, let's move forward finding another solution. Cheers
-S
]]>2015-10-01T15:02:49+01:002015-10-01T15:02:49+01:00https://brainmodular.org/forums/viewtopic.php?t=5112&p=33793#p33793Cheers.
F.
