Statistics: Posted by noise2sine — 02 Sep 2015, 14:02
]]>2015-09-01T16:04:28+02:002015-09-01T16:04:28+02:00https://brainmodular.org/forums/viewtopic.php?t=5076&p=33564#p33564you can of course start from the pad kontrol and add a sub patch delay and create all modifications you need, the community can help you on this.
Statistics: Posted by nay-seven — 01 Sep 2015, 16:04
]]>2015-09-01T10:36:10+02:002015-09-01T10:36:10+02:00https://brainmodular.org/forums/viewtopic.php?t=5076&p=33559#p33559Statistics: Posted by noise2sine — 01 Sep 2015, 10:36
2015-09-01T07:09:26+02:002015-09-01T07:09:26+02:00https://brainmodular.org/forums/viewtopic.php?t=5076&p=33556#p33556 Is this what you are talking about?
-s
Statistics: Posted by sephult — 01 Sep 2015, 07:09
]]>2015-08-31T17:36:24+02:002015-08-31T17:36:24+02:00https://brainmodular.org/forums/viewtopic.php?t=5076&p=33545#p33545I think i saw a drum rack module in Hollyhock close to the one proposed by ableton Live and unfortunatly i can't find it again, where can i find it ???
Statistics: Posted by noise2sine — 31 Aug 2015, 17:36
]]>2015-09-01T07:09:26+02:002015-09-01T07:09:26+02:00https://brainmodular.org/forums/viewtopic.php?t=5076&p=33556#p33556 Is this what you are talking about?
-s
