ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-07-25T08:40:19+01:00 https://brainmodular.org/forums/app.php/feed/topic/507 2007-07-25T08:40:19+01:00 2007-07-25T08:40:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=507&p=2439#p2439 <![CDATA[XY pad mouse click detector]]> As a "led" Mouse down witch has the value 1 when the mouse is pressed on the "bubble", 0 otherwise.
Statistics: Posted by senso — 25 Jul 2007, 09:40
2007-07-21T10:25:31+01:00 2007-07-21T10:25:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=507&p=2420#p2420 <![CDATA[XY pad mouse click detector]]> Statistics: Posted by senso — 21 Jul 2007, 11:25
2007-07-21T09:48:35+01:00 2007-07-21T09:48:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=507&p=2419#p2419 <![CDATA[XY pad mouse click detector]]>
About the Trajectory module, could you make different colours or something else to distinguish points and interpolation lines ?
I will try to explain with an example...
If I draw a continuous square, it will result to a continuous variation of the values. OK.
If I draw only four points at the corners, Usine draws lines between them and it looks also as a square, but there is only four points and the values jump from one to another. It is also OK.
But when I look at the two figures, it will be useful to see what are the points and what are only "visual link lines".
Statistics: Posted by jean-marc duchenne — 21 Jul 2007, 10:48
2007-07-20T17:19:44+01:00 2007-07-20T17:19:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=507&p=2414#p2414 <![CDATA[XY pad mouse click detector]]> also in the picture/bit map module.
I'll try to implement that soon.
Statistics: Posted by senso — 20 Jul 2007, 18:19
2007-07-20T15:08:36+01:00 2007-07-20T15:08:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=507&p=2412#p2412 <![CDATA[XY pad mouse click detector]]> Statistics: Posted by moody33 — 20 Jul 2007, 16:08
