ArrayArrayArray BrainModular BrainModular Users Forum 2015-08-26T16:35:19+02:00 https://brainmodular.org/forums/app.php/feed/topic/5067 2015-08-26T16:35:19+02:00 2015-08-26T16:35:19+02:00 https://brainmodular.org/forums/viewtopic.php?t=5067&p=33489#p33489 <![CDATA[Record Automation]]>
I would like to have at least a list of MIDI-Learn interface objects with Enable/Disable, this way when record is pressed, whenever the MIDI is received it records as Write-Enabled automation (without having to click the object with the mouse first).
Yes i need something like that. Just click or Arm Record with a midi control surface and all the knob and fader that i move on my controller, record Automation to the object that they are remote in Usine. Until i clik again to deactivate the Record Button.
It will be Great and very useful in live and composing research !!!
Statistics: Posted by cmodica — 26 Aug 2015, 16:35
2015-08-26T15:21:03+02:00 2015-08-26T15:21:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=5067&p=33488#p33488 <![CDATA[Record Automation]]> There is no specific Write-Enable, which just indicates to record it if it moves.
That is one of my latest suggestions to improve, in the suggestions forum.
If you agree post there as well and maybe we can improve a bit.
If you look at how Grid automation works, there are selections for which curve to show.
Somewhat similar....
-s
Statistics: Posted by sephult — 26 Aug 2015, 15:21
2015-08-26T15:11:56+02:00 2015-08-26T15:11:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=5067&p=33487#p33487 <![CDATA[Record Automation]]>
I can't find one. It seems that just mouse is enable to record automation ? Is it true ?
Why????
It seems so strange !!!!!!
Statistics: Posted by cmodica — 26 Aug 2015, 15:11
-s
Why????
