ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-08-25T18:47:19+01:00 https://brainmodular.org/forums/app.php/feed/topic/5034 2015-08-25T18:47:19+01:00 2015-08-25T18:47:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=5034&p=33481#p33481 <![CDATA[Usine Hollyhock II 2.0.078 update]]> They now include Triangle and separated Pink and White Noise...as well as being band-limited to prevent aliasing.
They sound much warmer and more smooth than the original.
Before they had a really raw harsh sound (which I didnt mind, actually I still like them too).
The LSeeD synth I put in the add-ons now uses the bandlimited oscillators, love them.
-s
Statistics: Posted by sephult — 25 Aug 2015, 19:47
2015-08-25T17:06:50+01:00 2015-08-25T17:06:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=5034&p=33479#p33479 <![CDATA[Usine Hollyhock II 2.0.078 update]]>
What is a band-limited osc? I'm googling, but not finding a simple answer.
Statistics: Posted by loneboat — 25 Aug 2015, 18:06
2015-08-05T12:28:56+01:00 2015-08-05T12:28:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=5034&p=33358#p33358 <![CDATA[Usine Hollyhock II 2.0.078 update]]> clip option in change scale will be veeeeery very useful !
Statistics: Posted by fractalist — 05 Aug 2015, 13:28
2015-08-02T15:36:44+01:00 2015-08-02T15:36:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=5034&p=33346#p33346 <![CDATA[Usine Hollyhock II 2.0.078 update]]>
The good news is that Usine has now a real band limited Oscillator which sounds good.
That is awesome news, putting to use right away!
The original oscillator sounded amazing to begin with, very excited to hear and implement in my synth patches.
Thanks Senso!
-s
Statistics: Posted by sephult — 02 Aug 2015, 16:36
2015-08-01T07:45:08+01:00 2015-08-01T07:45:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=5034&p=33345#p33345 <![CDATA[Usine Hollyhock II 2.0.078 update]]> Few improvements and bugs solved.
Also an important bug has been discovered on automations curves of the wave panel.
improvements
- new band limited oscillator module
- added random LFO mode
- up to 8 joysticks can be opened at the same time
- clip value options in the change scale module
bugs
- impossible to create curves points on a wave panel
Statistics: Posted by senso — 01 Aug 2015, 08:45
-s
Thanks Senso!
-s
improvements
bugs
