ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-07-20T12:24:11+01:00 https://brainmodular.org/forums/app.php/feed/topic/502 2007-07-20T12:24:11+01:00 2007-07-20T12:24:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=502&p=2408#p2408 <![CDATA[How to store a value?]]>
I hope you're ready to share this incomparable lady with all other Usiners!
Done : http://www.sensomusic.com/addons/
Statistics: Posted by moody33 — 20 Jul 2007, 13:24
2007-07-19T10:50:48+01:00 2007-07-19T10:50:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=502&p=2401#p2401 <![CDATA[How to store a value?]]> I hope you're ready to share this incomparable lady with all other Usiners!
Statistics: Posted by Vincent — 19 Jul 2007, 11:50
2007-07-18T18:33:21+01:00 2007-07-18T18:33:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=502&p=2399#p2399 <![CDATA[How to store a value?]]> Thanks you god.
Statistics: Posted by moody33 — 18 Jul 2007, 19:33
2007-07-18T18:12:50+01:00 2007-07-18T18:12:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=502&p=2398#p2398 <![CDATA[How to store a value?]]> if the midi input, you probably use the code1 or code2 value to modulate the parameter.
To store the last value in the patch, just add a new module between:
a math/variable
connect like that
in midi variable
code1 ---> in
receive ---> affect
out -----> parameter
the error "0x04483184" appears sometime at the end of the shutdown process. It has no consequences. Gennerally it comes a bad memory allocation of some plugins.
This bug arrive so lately that it's hard to fix. It's only a matter of time.
Statistics: Posted by senso — 18 Jul 2007, 19:12
2007-07-18T14:13:58+01:00 2007-07-18T14:13:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=502&p=2395#p2395 <![CDATA[How to store a value?]]>
I need to store the last incoming Midi code1 value( note on) automaticaly when I save a Workspace project whitout having to click on anything. Is it possible? How to?
Midi note---> Store last value and store it with the project--> Modulate a parameter.
Note: when I close Usine I've got this message : L'instruction à "0x04483184" emploie l'adresse mémoire "0x00000004". la mémoire ne peut pas être "read".
Any idea?
Statistics: Posted by moody33 — 18 Jul 2007, 15:13
a math/variable
connect like that
in midi variable
code1 ---> in
receive ---> affect
Any idea?
