ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-06-06T14:06:19+01:00 https://brainmodular.org/forums/app.php/feed/topic/4963 2015-06-06T14:06:19+01:00 2015-06-06T14:06:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33052#p33052 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Statistics: Posted by cmodica — 06 Jun 2015, 15:06
2015-06-05T20:06:23+01:00 2015-06-05T20:06:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33051#p33051 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Statistics: Posted by loneboat — 05 Jun 2015, 21:06
2015-06-05T19:49:43+01:00 2015-06-05T19:49:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33050#p33050 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> how Update and install
Statistics: Posted by cmodica — 05 Jun 2015, 20:49
2015-06-05T19:48:53+01:00 2015-06-05T19:48:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33049#p33049 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
There is a Wiki Loneboat!
Installation and Update
If you need more help let me know.
-s
Statistics: Posted by La Tenaille — 05 Jun 2015, 20:48
2015-06-05T19:30:13+01:00 2015-06-05T19:30:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33048#p33048 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Statistics: Posted by loneboat — 05 Jun 2015, 20:30
2015-06-04T04:59:45+01:00 2015-06-04T04:59:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33024#p33024 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
I can't keep up with you man, how do you do it!
Great catch.
BTW what happened to the email alerts?
-s
Statistics: Posted by sephult — 04 Jun 2015, 05:59
2015-06-03T22:30:56+01:00 2015-06-03T22:30:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33022#p33022 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Statistics: Posted by oli_lab — 03 Jun 2015, 23:30
2015-06-03T21:41:29+01:00 2015-06-03T21:41:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33021#p33021 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
(Rushes to work..)
Statistics: Posted by Sal — 03 Jun 2015, 22:41
2015-06-03T18:10:39+01:00 2015-06-03T18:10:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33020#p33020 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Important download, Buses names are not loaded correctly
Statistics: Posted by senso — 03 Jun 2015, 19:10
2015-06-03T03:06:23+01:00 2015-06-03T03:06:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33017#p33017 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
-s
Statistics: Posted by sephult — 03 Jun 2015, 04:06
2015-06-03T01:58:25+01:00 2015-06-03T01:58:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33016#p33016 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
[large]Usine Hollyhock II 2.0.071 RC11 update[/large]
Important download, the 071 has several important improvement and fixes reported bugs.
For a better stability, you should upgrade it.
improvements
Changes "loop on bar" and "loop on beat" behavior, more accurate
New bypass inlet on most of audio modules added
New Patch Bypass module to bypass the current patch
New default color set more punchy
New modules design in patches
New option in the setup/expert to disable the audio missing files dialog box
New option in the setup/expert to enable rounded setting on controls
New modules to get the language ID of Usine and used by the system
Simplification of the color palette file
bugs
Sync midi to grid displayed inverted
Wrong fade in/out durations on grid elements
Zoom scale reinitialization in old versions grid
Chat notification sound invalid
Ticket #099 : The color palette doesn't work properly on some controls
Ticket #022 : Problem with Enttec DMX-USB PRO mkII device
Drag&Drop from listbox doesn't work properly
[img align=L]http://www.sensomusic.com/img/features/ss12.png[/url]
Silly question: How do I upgrade? :-o
Statistics: Posted by loneboat — 03 Jun 2015, 02:58
2015-06-02T21:51:57+01:00 2015-06-02T21:51:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33014#p33014 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
Statistics: Posted by sephult — 02 Jun 2015, 22:51
2015-06-02T21:37:29+01:00 2015-06-02T21:37:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33013#p33013 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]>
Statistics: Posted by oli_lab — 02 Jun 2015, 22:37
2015-06-02T16:29:44+01:00 2015-06-02T16:29:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=4963&p=33009#p33009 <![CDATA[Usine Hollyhock II 2.0.071 RC11 update]]> Important download, the 071 has several important improvement and fixes reported bugs.
improvements
bugs
Statistics: Posted by senso — 02 Jun 2015, 17:29
-s
Great catch.
-s
(Rushes to work..)
-s
improvements
bugs
improvements
bugs
