ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2015-05-29T17:16:39+02:00https://brainmodular.org/forums/app.php/feed/topic/49542015-05-29T17:16:39+02:002015-05-29T17:16:39+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32981#p32981 found this calculator interesting also: http://sooeet.com/math/fourier-transform.php
here is a wip of my tests for an eq/filters module
]]>2015-05-29T16:45:40+02:002015-05-29T16:45:40+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32980#p32980 Thought you'd like this, since you like to roll your own: https://jakevdp.github.io/blog/2013/08/ ... g-the-fft/
]]>2015-05-29T11:53:48+02:002015-05-29T11:53:48+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32978#p32978 slowly start to catch. mind ya you won't have those problematics with patchs as the modules are well coded, but still can be interesting maybe..
so basically i generated oscilators like saw/sin or noise as test material, then after failing and failing with random FFT codes, i let dwn and decided to give a shot at performing a DFT instead (discrete fourier transform) So for first 'pass', feeding the samples as 'Reals' and set Imaginary to 0 was indeed the way to go, then the DFT algo returns the reals and imaginary filled according to samples material. then here i used a curved array as EQ to control directly the weight of both R and I, in fact no need for Polar/back to Cartesian convesions exept visual feedback purposes, just multiply by a factor works..then Invese DFT recomposed the filered wave. hurra^^ worked nice, but the sad thing is DFT is veryyy heavvvvy process on large chunks of datas..serious CPU hits on low freqs. so I struggled for a while again with few FFT codes and finally found a way to replicate, and it's much faster and workable this way. same process --->reset all Imag and Reals to 0,--->feed audio to Reals--->performs FFT--->process the weights to filter/control coefficients gains--->do the invese FFT. get filtered signal.where Reals are samples and Imag are back to 0. i made my first curved EQ im happy lol here i did a trick as i don't work 'real time' in process, i kinda make it 'offline' on the datas before they are played so didn't even't made a windowing function, anyway the modules will do the job automatically, but found interesting trying to catch the concepts behind.
]]>2015-05-26T23:42:38+02:002015-05-26T23:42:38+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32964#p32964Statistics: Posted by 23fx23 — 26 May 2015, 23:42
]]>2015-05-26T22:01:14+02:002015-05-26T22:01:14+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32961#p32961, implemented filters where some other bezier curves control/act as envellopes/lfo, working cool too, id just said myself why not go deeper with global graphical eq &/or custom filter responses bezier controlled as well^^
]]>2015-05-26T21:57:18+02:002015-05-26T21:57:18+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32960#p32960 it's kind of bezier synthetiser with all elements controlled via bezier (oscillators, envellopes, and filters), so ideally id like it to be hard coded
so it's the first and final conversion trick that i miss: how to get Reals and imaginary out of audio samples (-1...1) datas array, and on the other way, how to convert back to sample once process is done. mm
I'm really missing something... Getting R & I out of audio samples is exactly what the FFT does... Why not use the FFT? (Or its new PhVocForw?)
]]>2015-05-26T21:34:03+02:002015-05-26T21:34:03+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32957#p32957 but on the code part i could code the polar to catesian and reverse, and i found a FFT forward/inverse code, however it takes Real and Imaginary arrays as input, and return them once processed. so it's the first and final conversion trick that i miss: how to get Reals and imaginary out of audio samples (-1...1) datas array, and on the other way, how to convert back to sample once process is done. mm
in fact i just need to code this: but fail on the first and last module i think:
]]>2015-05-26T20:55:49+02:002015-05-26T20:55:49+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32956#p32956 1) Yes, that looks correct in theory. Only question is your 'array of samples' - which should be your audio stream in at the beginning & audio stream out at the end. 2) No, I don't believe so. If you fill imaginary with 0, you will lose phase information. You should feed both real & imaginary into carttopol & poltocart. 3) You need to use the Polar to Cartesian & Cartesian to Polar calls to do this math. You can Google these, they're very straightforward if you want to write your own. But HH2 has these modules. 4) The Inverse FFT does that, it 'reconstructs' your sound. The output of the inverse FFT function is your audio. 5) Excellent question...
Hope this helps... I'm still learning this. Experts, please chime in.
]]>2015-05-26T18:26:21+02:002015-05-26T18:26:21+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32955#p32955 well it's more a concept/math question since im trying to apply this on a use module.
what i am trying to achieve is kind of parametric visual EQ but using a bezier curve to control the frequency response, manipulating directly fft and not using pole filters.
ir's abit complex for me but i think it should be something like:
Array of Samples (-1...1) -----> extract FFT forward ------> convert Real and Imaginary to Magnitudes and Phases arrays -----> PROCESS magnitudes with my curve ----> convert back to R & I -----> Inverse FFT -----> get the samples out.
1rst Q: is this scheme right? semms ok when patching it, now i have to code it , it's here prb are coming.
2) is that ok method to fill a Real array with samples values, fill Imaginary with 0 and do FFT forward as the first process to extract FFT from a set of samples? or is it done differently?
3) any ideas of better math code to revert from magnitudes and phases to Real and Imaginaries?
4) Finally, how to convert back to sample audio data, just use Reals?
5) globally how to deal with size of audio 'sampled' buffer Vs size of FFT
]]>BrainModularBrainModular Users Forum2015-05-29T17:16:39+02:00https://brainmodular.org/forums/app.php/feed/topic/49542015-05-29T17:16:39+02:002015-05-29T17:16:39+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32981#p32981 found this calculator interesting also: http://sooeet.com/math/fourier-transform.php
]]>2015-05-26T22:46:58+02:002015-05-26T22:46:58+02:00https://brainmodular.org/forums/viewtopic.php?t=4954&p=32963#p32963
yes that would be easy, but im after a all in one code withouth wiring
Oh - you want to do this all in the SDK? I haven't used the SDK, I'm not sure how you get the internal audio blocks into the SDK.
My understanding is that your FFT formula should take the block of samples input & generate R & I output.
