Statistics: Posted by joffo78 — 17 May 2015, 02:01
]]>2015-05-17T01:54:14+02:002015-05-17T01:54:14+02:00https://brainmodular.org/forums/viewtopic.php?t=4934&p=32890#p32890 with 20 for min and 4000 for max for example You'll obtain a very fun r2d2 sound
Statistics: Posted by joffo78 — 17 May 2015, 01:54
Why didn't you use directly a basic random module with 20to20000 values Instead of rand midi + midi filter + midi to freq ? ..
No reason really. I was just experimenting with the MIDI functionality. I just discovered Hollyhock a few days ago, and have been having fun trying to figure everything out.
Statistics: Posted by loneboat — 16 May 2015, 22:04
]]>2015-05-16T11:33:14+02:002015-05-16T11:33:14+02:00https://brainmodular.org/forums/viewtopic.php?t=4934&p=32854#p32854Instead of rand midi + midi filter + midi to freq ? ..
Statistics: Posted by joffo78 — 16 May 2015, 11:33
]]>2015-05-15T22:09:46+02:002015-05-15T22:09:46+02:00https://brainmodular.org/forums/viewtopic.php?t=4934&p=32846#p32846Statistics: Posted by loneboat — 15 May 2015, 22:09
2015-05-15T21:51:47+02:002015-05-15T21:51:47+02:00https://brainmodular.org/forums/viewtopic.php?t=4934&p=32845#p32845 The Note to Freq just wants the note #.
To fix, put a MIDI Filter inbetween them. The MIDI Filter breaks down the MIDI message into its components. Leave it at 'no filter', so no actual filtering occurs. - Connect the RandMIDI note ON module's 'midi out' to the MIDI Filter's 'midi in'. - Connect the MIDI Filter's 'code1' to the Note to Freq's 'in' inlet.
I expected to hear random tones out through the oscillator, but I do not hear anything. I know my audio is set up properly, because if I hook up the knob to the oscillator freq directly, I can hear a tone just fine.
If I highlight the "RandMidi note On --> Note to Freq" connection I see the following data flowing:
If I highlight the "Note to Freq --> Oscillator" connection, I see the following:
Thanks!!
Statistics: Posted by loneboat — 15 May 2015, 21:40
]]>2015-05-15T21:51:47+02:002015-05-15T21:51:47+02:00https://brainmodular.org/forums/viewtopic.php?t=4934&p=32845#p32845 The Note to Freq just wants the note #.
Thanks!!
