ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-05-18T15:33:34+02:00 https://brainmodular.org/forums/app.php/feed/topic/4930 2015-05-18T15:33:34+02:00 2015-05-18T15:33:34+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32897#p32897 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 18 May 2015, 15:33
2015-05-16T19:02:07+02:00 2015-05-16T19:02:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32881#p32881 <![CDATA[Audio out via interface and iPad]]>
Demo works fine
you mean you have sound in the headphone of your soundcard ?
Statistics: Posted by nay-seven — 16 May 2015, 19:02
2015-05-16T18:23:23+02:00 2015-05-16T18:23:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32880#p32880 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 18:23
2015-05-16T18:22:23+02:00 2015-05-16T18:22:23+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32879#p32879 <![CDATA[Audio out via interface and iPad]]> every other DAW I use - simple and straightforward!
Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 18:22
2015-05-16T18:14:21+02:00 2015-05-16T18:14:21+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32878#p32878 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 18:14
2015-05-16T18:08:43+02:00 2015-05-16T18:08:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32877#p32877 <![CDATA[Audio out via interface and iPad]]> so forget the ipad for the moment, i suggest you to
-unzip a new version of Usine, rename it or start it directly from the download folder.
-set your soundcard as input and as output
-run one of the demo workspaces
Statistics: Posted by nay-seven — 16 May 2015, 18:08
2015-05-16T17:58:08+02:00 2015-05-16T17:58:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32876#p32876 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 17:58
2015-05-16T15:56:29+02:00 2015-05-16T15:56:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32871#p32871 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by nay-seven — 16 May 2015, 15:56
2015-05-16T15:08:43+02:00 2015-05-16T15:08:43+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32870#p32870 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 15:08
2015-05-16T15:08:11+02:00 2015-05-16T15:08:11+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32869#p32869 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 15:08
2015-05-16T14:37:44+02:00 2015-05-16T14:37:44+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32867#p32867 <![CDATA[Audio out via interface and iPad]]>
other explanation, if you have a mix software with your soundcard you can check its levels
Statistics: Posted by nay-seven — 16 May 2015, 14:37
2015-05-16T14:25:36+02:00 2015-05-16T14:25:36+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32866#p32866 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 14:25
2015-05-16T14:12:22+02:00 2015-05-16T14:12:22+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32865#p32865 <![CDATA[Audio out via interface and iPad]]> and as output in Usine, this you'll have sound at least on the headphones ?
Then, if you want to link your soundcard to your hifi system ( not always a good idea) , you can use its main hardware outputs
Statistics: Posted by nay-seven — 16 May 2015, 14:12
2015-05-16T14:03:53+02:00 2015-05-16T14:03:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32864#p32864 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 14:03
2015-05-16T13:58:28+02:00 2015-05-16T13:58:28+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32863#p32863 <![CDATA[Audio out via interface and iPad]]>
Statistics: Posted by nay-seven — 16 May 2015, 13:58
2015-05-16T13:53:14+02:00 2015-05-16T13:53:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32862#p32862 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 13:53
2015-05-16T13:47:55+02:00 2015-05-16T13:47:55+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32861#p32861 <![CDATA[Audio out via interface and iPad]]>
about the hardware solution , if your soundcard has good pre -amp you can link directly the ipad out mini jack to the 2 input of your soundcard?
Statistics: Posted by nay-seven — 16 May 2015, 13:47
2015-05-16T12:11:38+02:00 2015-05-16T12:11:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32856#p32856 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 12:11
2015-05-16T11:42:25+02:00 2015-05-16T11:42:25+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32855#p32855 <![CDATA[Audio out via interface and iPad]]> i try to read the user manual for this model, but there's many instruction for Windows, but very basic for Mac...
maybe you can start an appz on the ipad and activate all the inputs/outputs and see if you have levels in Usine ?
An other user tell me he use this appz, maybe it can help ? AudioMux
Statistics: Posted by nay-seven — 16 May 2015, 11:42
2015-05-16T11:10:29+02:00 2015-05-16T11:10:29+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32853#p32853 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 16 May 2015, 11:10
2015-05-15T18:17:59+02:00 2015-05-15T18:17:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32831#p32831 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 15 May 2015, 18:17
2015-05-15T18:15:27+02:00 2015-05-15T18:15:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32830#p32830 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 15 May 2015, 18:15
2015-05-15T16:13:35+02:00 2015-05-15T16:13:35+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32822#p32822 <![CDATA[Audio out via interface and iPad]]> so the hardware solution can be to run your ipad in the 2 input of your soundcard ?
the software solution is to create an aggregate audio interface where you choose first your ipad, then the sound card.Then choose it as input and as output in Usine.
with this solution the ipad will be the first 2 inputs , then activate the outputs 3/4 in the setup and create a new device for this outputs ( this correspond to your soundcard in second place)
Statistics: Posted by nay-seven — 15 May 2015, 16:13
2015-05-15T15:53:03+02:00 2015-05-15T15:53:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32818#p32818 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 15 May 2015, 15:53
2015-05-15T15:51:38+02:00 2015-05-15T15:51:38+02:00 https://brainmodular.org/forums/viewtopic.php?t=4930&p=32817#p32817 <![CDATA[Audio out via interface and iPad]]> Statistics: Posted by jon.gilhooly@talk21.com — 15 May 2015, 15:51
Demo works fine
