ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2016-12-20T01:50:46+01:00 https://brainmodular.org/forums/app.php/feed/topic/4921 2016-12-20T01:50:46+01:00 2016-12-20T01:50:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=36476#p36476 <![CDATA[Bezier Multi 1.0]]>
try the module version i changed inside this folder and open the workspace included, on top it show array generation mode, bottom is remapper mode example
https://drive.google.com/open?id=0B0VUy ... UFmUVkxNmc
Statistics: Posted by 23fx23 — 20 Dec 2016, 01:50
2016-12-19T21:03:19+01:00 2016-12-19T21:03:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=36474#p36474 <![CDATA[Bezier Multi 1.0]]>
Here's my test patch. I've tried every output from the bezier module, and I only get a flat line of values. I read the wiki, but it has different outputs and output names.
http://www.sensomusic.com/forums/upload ... erTest.pat
When I cable to 'x's', I get an array with the right shape, but it only has 7 values, although I specified 128.
when I cable to the test_0 output, I get 128 values, but they are all the same.
Statistics: Posted by woodslanding — 19 Dec 2016, 21:03
2016-10-23T17:40:07+01:00 2016-10-23T17:40:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=36107#p36107 <![CDATA[Bezier Multi 1.0]]> but i found a backup on external drive this morning :) , so checked and corrected few things.
should be less buggy now and allow more than one instance, cs let me know how it goes.
V1.1 fixed various memory allocations and global variables
W32-64 V1.1 user module:
https://drive.google.com/open?id=0B0VUy ... 0Q5amtVLVE
Ill uppgrade with a new version based on my synth that allow cool things like per segment custom curve type (bezier 2tan, bezier quad, linear spline intepolation ect)
and move/resize/scale eaily. but have to be patient. here is some teasing video by waiting^^
https://drive.google.com/open?id=0B0VUy ... kFKblJpRnM
Statistics: Posted by 23fx23 — 23 Oct 2016, 18:40
2016-07-18T12:35:54+01:00 2016-07-18T12:35:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=35613#p35613 <![CDATA[Bezier Multi 1.0]]> Just check if your variables are in" private "
Statistics: Posted by oli_lab — 18 Jul 2016, 13:35
2016-07-17T21:44:28+01:00 2016-07-17T21:44:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=35611#p35611 <![CDATA[Bezier Multi 1.0]]> ill try to have a look if i can find the source i used for this one.
Statistics: Posted by 23fx23 — 17 Jul 2016, 22:44
2016-07-14T16:44:22+01:00 2016-07-14T16:44:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=35610#p35610 <![CDATA[Bezier Multi 1.0]]> Best regards
Statistics: Posted by cs — 14 Jul 2016, 17:44
2015-05-13T12:09:49+01:00 2015-05-13T12:09:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=32770#p32770 <![CDATA[Bezier Multi 1.0]]> ,
Statistics: Posted by 23fx23 — 13 May 2015, 13:09
2015-05-13T11:42:55+01:00 2015-05-13T11:42:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=32768#p32768 <![CDATA[Bezier Multi 1.0]]>
I definitly need to get into GUI
Statistics: Posted by oli_lab — 13 May 2015, 12:42
2015-05-12T22:20:29+01:00 2015-05-12T22:20:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=4921&p=32766#p32766 <![CDATA[Bezier Multi 1.0]]>
Bezier Multi is a user module that creates a graphic canvas with multiple bezier curves.
Features:
_ Up to 8 curves accessible via menu buttons.
_ each curve can be up to 10 points with associated tangents.
_ each curve output defined size array.
_a time input allow to use each curve as a lfo , can be single for all or array for different times.
_various infos outputs like tangent angle and distance from point, currently touched point ect..
_extra menu for basic operation like reset to linear, reset to 2 points, mirror X, Y ect.
_ sequencer output can be smooth, quantisised X,Y or booth with XY grid setting.
_comma text input for user custom curves names,
_4 included skins with user skin editable colors.
_compatible with preset manager to save/recall differents sets of curves.
/addons data tools
nb let me know if find bugs
Statistics: Posted by 23fx23 — 12 May 2015, 23:20
Features:
/addons data tools
