ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2017-01-12T16:41:02+02:00https://brainmodular.org/forums/app.php/feed/topic/48682017-01-12T16:41:02+02:002017-01-12T16:41:02+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=36606#p36606 is the open DMX USB from Enttec is compatible on OSX and does it works on OSX with Usine ? Thanks in advance,
]]>2015-05-05T21:53:16+02:002015-05-05T21:53:16+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32650#p32650Statistics: Posted by julien_ — 05 May 2015, 21:53
2015-05-05T12:21:22+02:002015-05-05T12:21:22+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32633#p32633there is bug on the 068 you have to activate both options in the setup: - DMX active - Artnet active
in order to make dmx work properly in USB will be corrected in the 069 senso+++
]]>2015-04-24T14:21:27+02:002015-04-24T14:21:27+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32492#p32492Statistics: Posted by julien_ — 24 Apr 2015, 14:21
]]>2015-04-24T11:56:58+02:002015-04-24T11:56:58+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32489#p32489Statistics: Posted by nay-seven — 24 Apr 2015, 11:56
]]>2015-04-24T11:11:47+02:002015-04-24T11:11:47+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32488#p32488rien n'y fait, elle n'est plus reconnu. Y a t il une manip pour réinitialiser usine à ces "réglages d'usine"
Statistics: Posted by julien_ — 24 Apr 2015, 11:11
yesterday my enttec open usb dmx was recognized by usine and today no more...
rescan device button should make it appear, is the enttec device plugged in the same usb port than yesterday ?
Just Assign a DMX channel to the par created in the light universe in Usine, and program the physical dimmer with this same channel, that's it ?
make sure the plot panel setting is on universe 0 and point to the good device number
Statistics: Posted by martignasse — 23 Apr 2015, 18:08
]]>2015-04-23T15:35:28+02:002015-04-23T15:35:28+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32463#p32463still the problem to use it but furthermore no more recognize by usine yesterday my enttec open usb dmx was recognized by usine and today no more... it that a action to do to reset the dmx parameters ?
Statistics: Posted by julien_ — 23 Apr 2015, 15:35
]]>2015-04-21T13:23:45+02:002015-04-21T13:23:45+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32383#p32383i'd like to control my dimmer ( a starway tutelo ) with usine I ve followed the step by step tutorial from the DMX manual but it doens't work. i am a dmx newbie so maybe i am missing something. But it seems simple : Just Assign a DMX channel to the par created in the light universe in Usine, and program the physical dimmer with this same channel, that's it ?
Statistics: Posted by julien_ — 21 Apr 2015, 13:23
]]>BrainModularBrainModular Users Forum2017-01-12T16:41:02+02:00https://brainmodular.org/forums/app.php/feed/topic/48682017-01-12T16:41:02+02:002017-01-12T16:41:02+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=36606#p36606 is the open DMX USB from Enttec is compatible on OSX and does it works on OSX with Usine ? Thanks in advance,
]]>2015-05-05T12:21:22+02:002015-05-05T12:21:22+02:00https://brainmodular.org/forums/viewtopic.php?t=4868&p=32633#p32633there is bug on the 068 you have to activate both options in the setup: - DMX active - Artnet active
