2015-04-22T03:15:25+01:002015-04-22T03:15:25+01:00https://brainmodular.org/forums/viewtopic.php?t=4867&p=32425#p32425 I have a patch I am in the process of cleaning up and updating some things on that performs a probability based in step with the Synchro.
This is just a beta and I figured it could give you some ideas in yours as well. The bottom range fader shows the random triggering and the window of where it is possibly to trigger depending on the step. I put in upload for you, and will probably release an add-on soon. (Also built-in to my Advanced MIDI Sequencer that should be following)
in the data/random generator , there's a random trigger with a density parameter you can use it to trigger a pass flow module for your midi flow..?
Thanks Nay-Seven.
When I set it up as a device sending the original MIDI through a data bus it seems to work pretty well.
But the Random Trigger controls can't be contained in the device area so I tried setting it up like this:
But obviously that isn't working because the output is a float not a MIDI value. Tried sticking Quantize MIDI between Pass Flow and the plugin and still no luck. chrs Lloyd
]]>2015-04-21T11:23:12+01:002015-04-21T11:23:12+01:00https://brainmodular.org/forums/viewtopic.php?t=4867&p=32382#p32382you can use it to trigger a pass flow module for your midi flow..?
Statistics: Posted by nay-seven — 21 Apr 2015, 12:23
]]>2015-04-21T10:15:10+01:002015-04-21T10:15:10+01:00https://brainmodular.org/forums/viewtopic.php?t=4867&p=32381#p32381 I'm using Numerology in Rack one currently sending MIDI to MIDI Bus1. I want to create multiple racks with synth plugins and set a probability that the MIDI will pass through BUS1 to each synth. It could be a percentage probability where 100% is all pass and 0 % is never pass. It could also just be a RNG tested thing. I thought MIDI Filter might do this but it seems I need something like a switch. Any suggestions?
]]>BrainModularBrainModular Users Forum2015-04-23T22:03:22+01:00https://brainmodular.org/forums/app.php/feed/topic/48672015-04-23T22:03:22+01:002015-04-23T22:03:22+01:00https://brainmodular.org/forums/viewtopic.php?t=4867&p=32478#p32478Statistics: Posted by secretkillerofnames — 23 Apr 2015, 23:03
]]>2015-04-22T03:15:25+01:002015-04-22T03:15:25+01:00https://brainmodular.org/forums/viewtopic.php?t=4867&p=32425#p32425 I have a patch I am in the process of cleaning up and updating some things on that performs a probability based in step with the Synchro.
Thanks Nay-Seven.
