ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-04-18T19:39:01+01:00 https://brainmodular.org/forums/app.php/feed/topic/4857 2015-04-18T19:39:01+01:00 2015-04-18T19:39:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32325#p32325 <![CDATA[Bezier_Mapper]]> /////////////////////////////////////////////
_Fixed Inid bug that displays bezier now when dropping module for first time
_Fixed Bezier Function that could Lead to artefacts at the end of segment.
_Added New 'Algoritm' ListBox parameter to chose Between 2:
the old one Newton iterative search, more cpu efficient but that can behave weird with some tan settings,
Created a new one " Divide & Conquer' much more safier and accurate, but tiny more Cpu demanding.
_Increased Nb of possible max Iteration and reduced possible float precision for more accuracy if needed.
_Updated wiki
add/on data tools.
http://www.sensomusic.org/wiki3/doku.ph ... ier_mapper
Statistics: Posted by 23fx23 — 18 Apr 2015, 20:39
2015-04-18T01:27:53+01:00 2015-04-18T01:27:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32307#p32307 <![CDATA[Bezier_Mapper]]> think posting question here in the sdk forum area some will be bedtter advicers than me (like master martin^^) but if i know the answer of course ill help :)
Statistics: Posted by 23fx23 — 18 Apr 2015, 02:27
2015-04-18T00:36:25+01:00 2015-04-18T00:36:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32306#p32306 <![CDATA[Bezier_Mapper]]>
-S
Statistics: Posted by sephult — 18 Apr 2015, 01:36
2015-04-17T22:37:52+01:00 2015-04-17T22:37:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32303#p32303 <![CDATA[Bezier_Mapper]]> Statistics: Posted by 23fx23 — 17 Apr 2015, 23:37
2015-04-17T21:25:24+01:00 2015-04-17T21:25:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32302#p32302 <![CDATA[Bezier_Mapper]]> Statistics: Posted by 23fx23 — 17 Apr 2015, 22:25
2015-04-17T21:23:13+01:00 2015-04-17T21:23:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32301#p32301 <![CDATA[Bezier_Mapper]]>
btw, i've edit your seealso link in the wiki page ;)
Statistics: Posted by nay-seven — 17 Apr 2015, 22:23
2015-04-17T21:05:03+01:00 2015-04-17T21:05:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32300#p32300 <![CDATA[Bezier_Mapper]]>
i made a basic wiki if need more precisions
edit i forgot: tangents are linked by defult, press Shift whille tweaking one if wanna break
Statistics: Posted by 23fx23 — 17 Apr 2015, 22:05
2015-04-17T21:03:50+01:00 2015-04-17T21:03:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32299#p32299 <![CDATA[Bezier_Mapper]]> nice one Fox !
will be a useful module for sure
Statistics: Posted by nay-seven — 17 Apr 2015, 22:03
2015-04-17T20:28:24+01:00 2015-04-17T20:28:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=4857&p=32297#p32297 <![CDATA[Bezier_Mapper]]>
working on a Bezier Splines based serie of several modules (lfo/step/kick maker ect..)
This first one is somehow a remake of .Mapper Values module, but instead of having a coeff setting, the mapping is set via a bezier curve.
remaps in to out regarding max/min ranges and shape of the curve. works with arrays.
possibility to change nb of bezier points, to it will reinit the curve.
as bezier are quadratic functions, there is an inside algorithm to convert back to time domain 'linear' function based on newton's method iterative seach/approwimation, can set desired float precision and nb of iterations. while this method seemed to be the best cpu/result ratio, note it can lead to artefacts with to much tweaked input tangents.
let me know if working ok for ya.
add/on data tools
Statistics: Posted by 23fx23 — 17 Apr 2015, 21:28
_Updated wiki
add/on data tools.
-S
add/on data tools
