ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-04-19T20:25:52+01:00 https://brainmodular.org/forums/app.php/feed/topic/4854 2015-04-19T20:25:52+01:00 2015-04-19T20:25:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32343#p32343 <![CDATA[HSL Color Selector (user module) graphic version]]>
Statistics: Posted by ceasless — 19 Apr 2015, 21:25
2015-04-17T17:01:45+01:00 2015-04-17T17:01:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32291#p32291 <![CDATA[HSL Color Selector (user module) graphic version]]>
https://drive.google.com/file/d/0B0VUyz ... sp=sharing
Statistics: Posted by 23fx23 — 17 Apr 2015, 18:01
2015-04-17T16:39:51+01:00 2015-04-17T16:39:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32290#p32290 <![CDATA[HSL Color Selector (user module) graphic version]]>
Statistics: Posted by ceasless — 17 Apr 2015, 17:39
2015-04-17T10:20:30+01:00 2015-04-17T10:20:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32287#p32287 <![CDATA[HSL Color Selector (user module) graphic version]]>
you 're right nay should make a better preview, will think about it.
don't know if i broke someting or if normal (im on windows) but only had win32 and x64 as compile option in Ms visualstudio (demo, i only have 20days left to make plenty of modules ^^)
i can give the code of course, so martin can see all my beginner mistakes & teach me master tips haha
Statistics: Posted by 23fx23 — 17 Apr 2015, 11:20
2015-04-17T08:51:28+01:00 2015-04-17T08:51:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32286#p32286 <![CDATA[HSL Color Selector (user module) graphic version]]> hope someone can compile it for Mac , martignasse ?
Statistics: Posted by nay-seven — 17 Apr 2015, 09:51
2015-04-17T08:32:17+01:00 2015-04-17T08:32:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32284#p32284 <![CDATA[HSL Color Selector (user module) graphic version]]>
i have to test it
Nb: couldn't figure how to force initial size of module, so for best results size should be set to 400 to 400.
in onGetModuleInfo you can set pModuleInfo->DefaultWidth and pModuleInfo->DefaultHeight, is that what you are looking for ?
(i saw that they don't appear in the API docs, i'll make correction today)
Statistics: Posted by martignasse — 17 Apr 2015, 09:32
2015-04-17T04:15:52+01:00 2015-04-17T04:15:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=4854&p=32282#p32282 <![CDATA[HSL Color Selector (user module) graphic version]]>
As a training for sdk, Ive build a custom graphical HSL color selector ( and also cause im missing it :p)
it allows to selec a color in 2 clics.
1) pick Hue in the 360 hue wheel
2) pick XY sat and lum in center square.
Outputs usine color and text HexValue. if wanna apply in usine color selector.
maybe drop in a contener and save as patch if find interesting to use.
ill try to improve..
ie the hue wheel doesn't really need to be computated and could be replaced by a still jpg in next version.
win32 win64 (couldnt compile mac :/
HSL color selector graphic version
hope some may enjoy. cheerz
Statistics: Posted by 23fx23 — 17 Apr 2015, 05:15
i have to test it
