ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-04-15T11:33:31+01:00 https://brainmodular.org/forums/app.php/feed/topic/4833 2015-04-15T11:33:31+01:00 2015-04-15T11:33:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32259#p32259 <![CDATA[modules to map multiple parameters to a single array]]>
I actually did a script to do Serial to Array, and vice versa for my needs.
So the get and set modules can be used, as well as the que data module for doing such thing.
You could create a polyphonic sub-patch to do such a think with pure-modules rather than a script.
If you are needing help let me know.
-S
Hi Sephult,
Your script Serial to Array would be very useful. Is it possible to get it ? I try to manage a serial datas from Arduino, but "Queue Data in Array" is not working properly. It's fine with a single parameter.
Many thanks
Statistics: Posted by rlgsbt — 15 Apr 2015, 12:33
2015-04-08T15:28:01+01:00 2015-04-08T15:28:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32135#p32135 <![CDATA[modules to map multiple parameters to a single array]]>
-S
Hi Sephult.
Serial to array would be very useful I can see, but I do not need it in this case.
I am still messing with my midi controller patch. Since it has a bunch of graphical widgets per "zone", all the inputs were getting out of hand and taking a lot of wiring up.
So my latest idea is to combine all the parameters for each zone into a sub-patch, with a single array output per sub-patch, then use polyphony to duplicate the zones, and only 1 wire per zone sub-patch instead of many.
Simon.
Statistics: Posted by sm_jamieson — 08 Apr 2015, 16:28
2015-04-08T15:12:19+01:00 2015-04-08T15:12:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32134#p32134 <![CDATA[modules to map multiple parameters to a single array]]>
It depends on the kind of the "x"
If I understand your question correctly, it may be very easy. If your Xs are coming from seperate sources, use an array module with up to 128 faders and connect your seperate sources to fader inputs, then the red output pin of the array module gives you a single array output.
Yes it is separate sources into an array. I saw the "array - display or set" module and chose "no faders" as I thought it would be drawing some type of faders on the screen. In fact, you get the "fader/display" graphic anyway, which can be set invisible of course, but the number of "faders" seems to in fact be inputs for faders (or any other data source) to be connected to.
Thanks for pointing me in the right direction.
Simon.
Statistics: Posted by sm_jamieson — 08 Apr 2015, 16:12
2015-04-08T14:21:53+01:00 2015-04-08T14:21:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32131#p32131 <![CDATA[modules to map multiple parameters to a single array]]> So the get and set modules can be used, as well as the que data module for doing such thing.
-S
Statistics: Posted by sephult — 08 Apr 2015, 15:21
2015-04-08T14:09:13+01:00 2015-04-08T14:09:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32129#p32129 <![CDATA[modules to map multiple parameters to a single array]]> If I understand your question correctly, it may be very easy. If your Xs are coming from seperate sources, use an array module with up to 128 faders and connect your seperate sources to fader inputs, then the red output pin of the array module gives you a single array output.
Statistics: Posted by Question — 08 Apr 2015, 15:09
2015-04-08T12:56:26+01:00 2015-04-08T12:56:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=4833&p=32123#p32123 <![CDATA[modules to map multiple parameters to a single array]]>
Also, is there a module that works the other way, i.e. a single array input parameter converting to X number of output parameters ?
In the above, X = a variable number of parameters = array size.
Or do I have to write a script to do this ?
Simon.
Statistics: Posted by sm_jamieson — 08 Apr 2015, 13:56
-S
Hi Sephult,
Many thanks
-S
Hi Sephult.
Simon.
Simon.
-S
Simon.
