ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2018-02-21T22:46:12+01:00 https://brainmodular.org/forums/app.php/feed/topic/4805 2018-02-21T22:46:12+01:00 2018-02-21T22:46:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39463#p39463 <![CDATA[combine 2 ARRAY]]>
one main problem with it - the event arrays lose the midi channel information so everything in a midi file gets mixed together - melody, drums, etc
plus the whole thing is quite clunky. i was wondering how the array 'rows' and 'lines' worked - there is no explanation at all in the manual. could this be a way of splitting up the midi data?
Statistics: Posted by bmartin — 21 Feb 2018, 22:46
2018-02-06T22:33:56+01:00 2018-02-06T22:33:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39307#p39307 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by bmartin — 06 Feb 2018, 22:33
2018-02-04T13:57:55+01:00 2018-02-04T13:57:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39249#p39249 <![CDATA[combine 2 ARRAY]]>
no, sorry, i'm on a mac!
too bad, you'll have to wait few more days, I only start the mac mini when building user modules !
Statistics: Posted by oli_lab — 04 Feb 2018, 13:57
2018-02-04T10:29:18+01:00 2018-02-04T10:29:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39246#p39246 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by bmartin — 04 Feb 2018, 10:29
2018-02-04T02:33:15+01:00 2018-02-04T02:33:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39244#p39244 <![CDATA[combine 2 ARRAY]]>
I will make a proper release with osx build asap
File uploaded: http://www.sensomusic.com/forums/upload ... _Array.zip
Statistics: Posted by oli_lab — 04 Feb 2018, 02:33
2018-02-03T23:14:54+01:00 2018-02-03T23:14:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39242#p39242 <![CDATA[combine 2 ARRAY]]>
I've just finished the deserializer 1 to 5...
I'll do the serializer 5 to 1 asap
thanks, that looks like it could be useful for other things but it's not quite what I'm looking for.
I mean something that will split the event array into a set of other arrays like 'note array', 'velocity array' etc so that those could be manipulated as groups, swapped around etc and then put back into an event array for the piano roll.
(I'm trying to recreate some of the tricks that could be performed with the old 'KeyKit' software)
There is a user module that parse the array out of the piano roll : it is called "play midi note"
you'll find it with the addons
Statistics: Posted by bmartin — 03 Feb 2018, 23:14
2018-02-03T21:20:28+01:00 2018-02-03T21:20:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39239#p39239 <![CDATA[combine 2 ARRAY]]> I'll do the serializer 5 to 1 asap
Statistics: Posted by oli_lab — 03 Feb 2018, 21:20
2018-02-03T14:01:36+01:00 2018-02-03T14:01:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39236#p39236 <![CDATA[combine 2 ARRAY]]> I mean something that will split the event array into a set of other arrays like 'note array', 'velocity array' etc so that those could be manipulated as groups, swapped around etc and then put back into an event array for the piano roll.
Statistics: Posted by bmartin — 03 Feb 2018, 14:01
2018-02-03T13:37:02+01:00 2018-02-03T13:37:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39235#p39235 <![CDATA[combine 2 ARRAY]]> you'll find it with the addons
Statistics: Posted by oli_lab — 03 Feb 2018, 13:37
2018-02-03T10:31:08+01:00 2018-02-03T10:31:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=39234#p39234 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by bmartin — 03 Feb 2018, 10:31
2015-05-01T15:57:58+01:00 2015-05-01T15:57:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32590#p32590 <![CDATA[combine 2 ARRAY]]> i've just download and test the module (user module) "weave array" from oli lab
it's work perfectly,
I don't understand scripting
but a great thanks to all,
Statistics: Posted by gercha1 — 01 May 2015, 16:57
2015-05-01T15:34:58+01:00 2015-05-01T15:34:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32589#p32589 <![CDATA[combine 2 ARRAY]]>
It would be cool if gercha1 could confirm whether this is doing what he needs though ;)
Statistics: Posted by ceasless — 01 May 2015, 16:34
2015-04-22T11:48:33+01:00 2015-04-22T11:48:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32439#p32439 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by 23fx23 — 22 Apr 2015, 12:48
2015-04-22T09:23:26+01:00 2015-04-22T09:23:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32432#p32432 <![CDATA[combine 2 ARRAY]]> could be cool is someone else test, cause you and 23fx have development tools on your machine, so this can false the results..?
Statistics: Posted by nay-seven — 22 Apr 2015, 10:23
2015-04-22T09:07:20+01:00 2015-04-22T09:07:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32431#p32431 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by ceasless — 22 Apr 2015, 10:07
2015-04-20T13:07:07+01:00 2015-04-20T13:07:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32363#p32363 <![CDATA[combine 2 ARRAY]]> yup maybe it's the raw thing, shouldn't need a dll once compiled normally nope?
Statistics: Posted by 23fx23 — 20 Apr 2015, 14:07
2015-04-20T08:05:07+01:00 2015-04-20T08:05:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32355#p32355 <![CDATA[combine 2 ARRAY]]>
To make sure you are downloading the actual binary, you need to click on the file, and then click 'View raw'. This will download the binary. If you right-click "save as" anything that does not say "raw", you will not be doanloading the binary.
Statistics: Posted by ceasless — 20 Apr 2015, 09:05
2015-04-19T23:32:59+01:00 2015-04-19T23:32:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32352#p32352 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by 23fx23 — 20 Apr 2015, 00:32
2015-04-19T22:43:03+01:00 2015-04-19T22:43:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32349#p32349 <![CDATA[combine 2 ARRAY]]>
Make sure you are downloading the 'raw' version of the file from github. Or download the zip and get the files from there.
Anyway these will be available more easily through Usine's great add-ons system.
Statistics: Posted by ceasless — 19 Apr 2015, 23:43
2015-04-19T22:11:48+01:00 2015-04-19T22:11:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32348#p32348 <![CDATA[combine 2 ARRAY]]>
looks ok on HH2 64bits
I'l try to upload on github...I'm confused...
it's all there on wetransfer
https://www.wetransfer.com/downloads/7a ... 215/84c1c0
olivar
Statistics: Posted by oli_lab — 19 Apr 2015, 23:11
2015-04-19T20:56:39+01:00 2015-04-19T20:56:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32346#p32346 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by nay-seven — 19 Apr 2015, 21:56
2015-04-19T20:52:01+01:00 2015-04-19T20:52:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32345#p32345 <![CDATA[combine 2 ARRAY]]>
Can't start the program , cause MSVCP120D.dll is missing on this computer ?
test on a 64 win seven, usine 32 and usine 64
On Mac 10.8.5, no message but the module has no name and it's invalid
Statistics: Posted by nay-seven — 19 Apr 2015, 21:52
2015-04-19T19:43:58+01:00 2015-04-19T19:43:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32342#p32342 <![CDATA[combine 2 ARRAY]]>
Or you can upload and send a link and I van add them.
Probably best for you to post those in the grove thread, so things don't get too confused.
Statistics: Posted by ceasless — 19 Apr 2015, 20:43
2015-04-19T19:17:57+01:00 2015-04-19T19:17:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32341#p32341 <![CDATA[combine 2 ARRAY]]> I have a few modules I'll be happy to share (source and Windows builds)
Can I put them on the 'Grove ?
Statistics: Posted by oli_lab — 19 Apr 2015, 20:17
2015-04-19T17:56:22+01:00 2015-04-19T17:56:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=4805&p=32340#p32340 <![CDATA[combine 2 ARRAY]]> Statistics: Posted by 23fx23 — 19 Apr 2015, 18:56
olivar
