ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-08-19T08:33:44+01:00 https://brainmodular.org/forums/app.php/feed/topic/4785 2015-08-19T08:33:44+01:00 2015-08-19T08:33:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=33425#p33425 <![CDATA[FLAC support]]>
Statistics: Posted by Jongleur — 19 Aug 2015, 09:33
2015-04-22T07:44:20+01:00 2015-04-22T07:44:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32429#p32429 <![CDATA[FLAC support]]> Statistics: Posted by Jongleur — 22 Apr 2015, 08:44
2015-04-11T10:46:18+01:00 2015-04-11T10:46:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32205#p32205 <![CDATA[FLAC support]]> yet. :)
Statistics: Posted by ceasless — 11 Apr 2015, 11:46
2015-04-11T08:15:10+01:00 2015-04-11T08:15:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32203#p32203 <![CDATA[FLAC support]]>
Not just open minded, but fundamentally open. No patents, no royalties, no reason not to support :)
maybe the time, a matter of priority?:)
Statistics: Posted by senso — 11 Apr 2015, 09:15
2015-04-10T14:55:12+01:00 2015-04-10T14:55:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32186#p32186 <![CDATA[FLAC support]]>
Would that mean that you need to "hard-convert" the FLAC to wav/aif on disk or can you play back the file without conversion?
Because converting them to wav is what I want to avoid - I have tools that can do that already, but I would like to keep the footprint of those libraries on disk as small as possible.
I also started to use FLAC a lot for surround work, since it is one of the best delivery formats for it IMO.
With multichannel support, every bit- and sample rate under the sun and about half the size of uncompressed audio without losing quality it's really nice - and Audacity handles it very well.
So my Bandcamp projects use multichannel FLAC to deliver the 5.1 surround version (as "bonus item" since Bandcamp doesn't directly support surround yet):
http://excerpts-of-infinity.bandcamp.co ... at-i-on-ii
https://thomashelzle.bandcamp.com/album ... l-nature-2
There also is a brilliant player for such multichannel files (and all others as well): http://resonic.at/
So if it fit's into your concept for Usine, it could be a rather cool addition for in- and output.
Cheers,
Tom
Statistics: Posted by Thomas Helzle — 10 Apr 2015, 15:55
2015-04-09T14:32:02+01:00 2015-04-09T14:32:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32169#p32169 <![CDATA[FLAC support]]>
Statistics: Posted by ceasless — 09 Apr 2015, 15:32
2015-04-09T14:26:05+01:00 2015-04-09T14:26:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32168#p32168 <![CDATA[FLAC support]]>
and they seem to have a very open-minded license approach
..https://xiph.org/flac/license.html
Statistics: Posted by iococoi — 09 Apr 2015, 15:26
2015-04-09T13:13:07+01:00 2015-04-09T13:13:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=32162#p32162 <![CDATA[FLAC support]]> Normally we have to pay royalties for that.
Statistics: Posted by senso — 09 Apr 2015, 14:13
2015-03-27T00:41:53+01:00 2015-03-27T00:41:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=31825#p31825 <![CDATA[FLAC support]]> Mostly raw .wav, rex, and mp3.
.rex conversion to grain sampler would be really cool, except the fact that you need Recycle, or a license for export.
-S
Statistics: Posted by sephult — 27 Mar 2015, 00:41
2015-03-27T00:05:59+01:00 2015-03-27T00:05:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=4785&p=31824#p31824 <![CDATA[FLAC support]]>
I just stumbled over the fact that FLAC isn't supported in the Usine samplers.
I seem to get more and more samples in this format - would it be possible to support it natively without converting or is that a bad idea for some reason?
Thanks!
Tom
Statistics: Posted by Thomas Helzle — 27 Mar 2015, 00:05
Cheers,
Tom
-S
Thanks!
Tom
