ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-03-27T16:26:59+02:00 https://brainmodular.org/forums/app.php/feed/topic/4784 2015-03-27T16:26:59+02:00 2015-03-27T16:26:59+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31863#p31863 <![CDATA[modulating pitch bend on a vst]]>
Regardless, you now have at least some commented example to help you build some MIDI with, or learn how to adapt some controls once you get your pitchbend question resolved.
I see Nay and Drakh are helping. I will leave this to them.
If you have any questions about the patch I sent you, you can go ahead and address them here help you get going with HH.
-S
Statistics: Posted by sephult — 27 Mar 2015, 15:26
2015-03-27T12:40:49+02:00 2015-03-27T12:40:49+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31839#p31839 <![CDATA[modulating pitch bend on a vst]]>
i go to the patch forum now
Statistics: Posted by ahs — 27 Mar 2015, 11:40
2015-03-27T09:19:00+02:00 2015-03-27T09:19:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31833#p31833 <![CDATA[modulating pitch bend on a vst]]> Statistics: Posted by ahs — 27 Mar 2015, 08:19
2015-03-27T09:17:39+02:00 2015-03-27T09:17:39+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31832#p31832 <![CDATA[modulating pitch bend on a vst]]>
Statistics: Posted by ahs — 27 Mar 2015, 08:17
2015-03-26T18:41:14+02:00 2015-03-26T18:41:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31818#p31818 <![CDATA[modulating pitch bend on a vst]]>
Also it is probably more appropriate to post specific patch questions in the patching questions section of the forum.
This at least prevent confusion and help us keep reference.
-S
Statistics: Posted by sephult — 26 Mar 2015, 17:41
2015-03-26T18:21:48+02:00 2015-03-26T18:21:48+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31814#p31814 <![CDATA[modulating pitch bend on a vst]]>
I made you a simple patch with some comments within the patch edit to help you understand.
It is basically two examples using the output of an XY pad to convert to MIDI or different values, and the second is an LFO output to MIDI
I am driving MIDI to the VST in this example, instead of direct however once you start getting the logic it becomes simple to modify for your needs.
Let me know if this helps or not....or you have other questions.
ahs modulation example patch
Statistics: Posted by sephult — 26 Mar 2015, 17:21
2015-03-26T17:49:09+02:00 2015-03-26T17:49:09+02:00 https://brainmodular.org/forums/viewtopic.php?t=4784&p=31809#p31809 <![CDATA[modulating pitch bend on a vst]]> Statistics: Posted by ahs — 26 Mar 2015, 16:49
-S
-S
