ArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-03-03T15:14:17+01:00 https://brainmodular.org/forums/app.php/feed/topic/4726 2015-03-03T15:14:17+01:00 2015-03-03T15:14:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=4726&p=31444#p31444 <![CDATA[FastScript - TParameter of Array: How to do Callback]]>
Seems now its working for me, yes I did have to define the label as an index....now it seems to take the other Tparameters I put.
I am going to chalk it up to me :)
Thanks for your help Simon!
-S
Statistics: Posted by sephult — 03 Mar 2015, 15:14
2015-03-03T14:37:22+01:00 2015-03-03T14:37:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=4726&p=31443#p31443 <![CDATA[FastScript - TParameter of Array: How to do Callback]]>
Thank you for your help!
My brain has not had enough coffee this morning...and still very dense :P
I was wondering the same thing, however looking at a script such as the MIDI Arpeggiator they seemed to just reference the Tparameter variable.
No you are correct about the pad[0], pad[1], etc... Interestingly enough if I put pad[0] etc...the compiler takes it and if I put another Tparameter it won't.
-S
Statistics: Posted by sephult — 03 Mar 2015, 14:37
2015-03-03T14:23:08+01:00 2015-03-03T14:23:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=4726&p=31441#p31441 <![CDATA[FastScript - TParameter of Array: How to do Callback]]> Anyway, did you mean pad[0], pad[1], etc. unless you have declared "pad0" and "pad1" elsewhere.
If you want to use variables you will have to use "if" instead of "case", e.g.
var pad : array [0..15] of Tparameter;
procedure callback (n:integer);
Begin
if n = pad[0] then ...
else
if n = pad[1] then ...
end;
Simon.
Statistics: Posted by sm_jamieson — 03 Mar 2015, 14:23
2015-03-03T13:55:09+01:00 2015-03-03T13:55:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=4726&p=31440#p31440 <![CDATA[FastScript - TParameter of Array: How to do Callback]]>
Sorry for Topic confusion I meant to say Array of Tparameter:
So I am running into an interesting problem.
I have an Array of Tparameter , and I am wanting to control by a Callback event referring to the name.
As example:
Begin
Case n of
pad0 :
pad1 :
etc..
It seems like the compiler does not understand that pad0 is a real Tparameter, because the iteration to create happens in the init procedure.
At least this is what I am assuming.
I was hoping to refer by name, as in previous scripts I have always had problems where I had to add another parameter and had to adjust the
entire callback procedure respectively to match the IO number.
Am I doing something wrong? Is there a different way to approach?
If this is the case, I guess it would probably be beneficial to update the compiler to accept that a Tparameter is an array of a specified length.
-S
Statistics: Posted by sephult — 03 Mar 2015, 13:55
-S
-S
Begin
else
end;
Simon.
As example:
Begin
Case n of
pad0 :
pad1 :
etc..
-S
