ArrayArray BrainModular BrainModular Users Forum 2015-03-10T17:15:58+01:00 https://brainmodular.org/forums/app.php/feed/topic/4720 2015-03-10T17:15:58+01:00 2015-03-10T17:15:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4720&p=31560#p31560 <![CDATA[letter with accent]]>
solution for me is to use an array as the input string :
// encode morse code !
// parameters declaration
var input : Tparameter;
var output : Tparameter;
var reset : Tparameter;
var setStr : Tparameter;
//var s1 : String;
var st : string;
var stout : string;
// destroy
procedure Destroy;
begin
//s1.free;
end;
procedure init;
begin
SetModuleColor($FFFF80);
Input := CreateParam('text',ptArray);
SetIsOutPut(Input,false);
reset := CreateParam('reset',ptDataField);
SetIsOutPut(reset,false);
setStr := CreateParam('set',ptDataField);
SetIsOutPut(setStr,false);
output := CreateParam('code morse sequence',ptTextField);
SetIsInPut(Output,false);
//S1.Create;
end;
procedure Callback(n:integer);
//var st : string;
//var stout : string;
var i : integer;
var c : single;
var size : integer;
Var tab1 : array of integer;
var arraysize : integer
begin
if (n = 2)AND(GetValue(setStr) = 1) then begin
//SetStringValue(output, '');
SetStringValue(output,GetStringValue(output) + '000000000');
size := GetLength(input);
//sTrace('size');
//iTrace(size);
for i := 0 to size do begin
c := getDataArrayValue(input,i);
//sTrace(c);
//iTrace(i);
if (c = 83 ) then
begin
//sTrace('detecte un ?');
SetStringValue(output,GetStringValue(output) + '101011101110101000');
end
else if ((c = 65 )OR(c = 97)OR(c = 224)) then
begin
//sTrace('detecte un a');
SetStringValue(output,GetStringValue(output) + '1010111000');
end
else if ((c = 66 )OR(c = 98)) then
begin
//sTrace('detecte un b');
SetStringValue(output,GetStringValue(output) + '111010101000');
end
else if ((c = 67 )OR(c = 99)OR(c = 231)) then
begin
SetStringValue(output,GetStringValue(output) + '11101011101000');
end
else if ((c = 68 )OR(c = 100)) then
begin
SetStringValue(output,GetStringValue(output) + '1110101000');
end
else if ((c = 69 )OR(c = 101)OR(c = 233)OR(c = 232)OR(c = 234)) then
begin
SetStringValue(output,GetStringValue(output) + '1000');
end
else if ((c = 70 )OR(c = 102)) then
begin
SetStringValue(output,GetStringValue(output) + '101011101000');
end
else if ((c = 71 )OR(c = 103)) then
begin
SetStringValue(output,GetStringValue(output) + '111011101000');
end
else if ((c = 72 )OR(c = 104)) then
begin
SetStringValue(output,GetStringValue(output) + '1010101000');
end
else if ((c = 73 )OR(c = 105)) then
begin
SetStringValue(output,GetStringValue(output) + '101000');
end
else if ((c = 74 )OR(c = 106)) then
begin
SetStringValue(output,GetStringValue(output) + '1011101110111000');
end
else if ((c = 75 )OR(c = 107)) then
begin
SetStringValue(output,GetStringValue(output) + '111010111');
end
else if ((c = 76 )OR(c = 108)) then
begin
SetStringValue(output,GetStringValue(output) + '101110101000');
end
else if ((c = 77 )OR(c = 109)) then
begin
SetStringValue(output,GetStringValue(output) + '1110111000');
end
else if ((c = 78 )OR(c = 110)) then
begin
SetStringValue(output,GetStringValue(output) + '11101000');
end
else if ((c = 79 )OR(c = 111)) then
begin
SetStringValue(output,GetStringValue(output) + '11101110111000');
end
else if ((c = 80 )OR(c = 112)) then
begin
SetStringValue(output,GetStringValue(output) + '10111011101000');
end
else if ((c = 81 )OR(c = 113)) then
begin
SetStringValue(output,GetStringValue(output) + '1110111010111000');
end
else if ((c = 82 )OR(c = 114)) then
begin
SetStringValue(output,GetStringValue(output) + '1011101000');
end
else if ((c = 83 )OR(c = 115)) then
begin
SetStringValue(output,GetStringValue(output) + '10101000');
end
else if ((c = 84 )OR(c = 116)) then
begin
SetStringValue(output,GetStringValue(output) + '111000');
end
else if ((c = 85 )OR(c = 117)) then
begin
//sTrace('detecte un u');
end
else if ((c = 86 )OR(c = 118)) then
begin
SetStringValue(output,GetStringValue(output) + '101010111000');
end
else if ((c = 87 )OR(c = 119)) then
begin
SetStringValue(output,GetStringValue(output) + '101110111000');
end
else if ((c = 88 )OR(c = 120)) then
begin
SetStringValue(output,GetStringValue(output) + '11101010111000');
end
else if ((c = 89 )OR(c = 121)) then
begin
SetStringValue(output,GetStringValue(output) + '1110101110111000');
end
else if ((c = 90 )OR(c = 122)) then
begin
SetStringValue(output,GetStringValue(output) + '11101110101000');
end
else if (c = 48 ) then
begin
SetStringValue(output,GetStringValue(output) + '10111010111010111000');
end
else if (c = 44 ) then
begin
SetStringValue(output,GetStringValue(output) + '1110111010101110111000');
end
else if (c = 47 ) then
begin
SetStringValue(output,GetStringValue(output) + '1110101011101000');
end
else if (c = 64 ) then
begin
SetStringValue(output,GetStringValue(output) + '10111011101011101000');
end
else if (c = 49 ) then
begin
SetStringValue(output,GetStringValue(output) + '10111011101110111000');
end
else if (c = 50 ) then
begin
SetStringValue(output,GetStringValue(output) + '101011101110111000');
end
else if (c = 51 ) then
begin
SetStringValue(output,GetStringValue(output) + '1010101110111000');
end
else if (c = 52 ) then
begin
SetStringValue(output,GetStringValue(output) + '10101010111000');
end
else if (c = 53 ) then
begin
SetStringValue(output,GetStringValue(output) + '101010101000');
end
else if (c = 54 ) then
begin
SetStringValue(output,GetStringValue(output) + '11101010101000');
end
else if (c = 55 ) then
begin
SetStringValue(output,GetStringValue(output) + '111011101010101000');
end
else if (c = 56 ) then
begin
SetStringValue(output,GetStringValue(output) + '111011101110101000');
end
else if (c = 57 ) then
begin
SetStringValue(output,GetStringValue(output) + '11101110111011101000');
end
begin
SetStringValue(output,GetStringValue(output) + '1110111011101110111000');
end
else if (c = 32 ) then
begin
SetStringValue(output,GetStringValue(output) + '0000');
end
else
SetStringValue(output,GetStringValue(output));
end;
end;
if (n = 1) then begin
end;
//SetStringValue(Output,stout);
end;
// no process bloc
Statistics: Posted by oli_lab — 10 Mar 2015, 17:15
2015-02-25T00:31:12+01:00 2015-02-25T00:31:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=4720&p=31411#p31411 <![CDATA[letter with accent]]> I'm making a morse code encoder...
I have trouble with accentuated letter as à, é, è, as well as with the question mark...
it is ok with an 'a' or an 'A' but could no detect the à (neither '&agrave')
any idea ?
he is a except of the script :
procedure Callback(N:integer);
//var st : string;
var i : integer;
var c : char;
var size : integer;
begin
st := (GetStringValue(Input));
size := Length(st);
//sTrace('size');
//iTrace(size);
c := st;
//sTrace(c);
//iTrace(i);
if ((c = 'a' )OR(c = 'A')OR(c = 'à')) then
begin
end
else if ((c = 'b' )OR(c = 'B')) then
begin
end
Statistics: Posted by oli_lab — 25 Feb 2015, 00:31
//var s1 : String;
var st : string;
var stout : string;
// destroy
procedure Destroy;
begin
//s1.free;
end;
procedure init;
begin
//S1.Create;
end;
//var st : string;
var i : integer;
var c : single;
var size : integer;
begin
//sTrace('size');
//iTrace(size);
//sTrace(c);
//iTrace(i);
if (c = 83 ) then
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
else
end;
end;
end;
end;
// no process bloc
any idea ?
//var st : string;
var i : integer;
var c : char;
var size : integer;
begin
size := Length(st);
//sTrace('size');
//iTrace(size);
c := st;
//sTrace(c);
//iTrace(i);
begin
end
begin
end
