ArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-03-04T12:13:32+01:00 https://brainmodular.org/forums/app.php/feed/topic/4702 2015-03-04T12:13:32+01:00 2015-03-04T12:13:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=4702&p=31452#p31452 <![CDATA[problematic vst parameter resolution]]> Statistics: Posted by soundmind — 04 Mar 2015, 12:13
2015-03-04T09:38:26+01:00 2015-03-04T09:38:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=4702&p=31449#p31449 <![CDATA[problematic vst parameter resolution]]> senso+++
Statistics: Posted by senso — 04 Mar 2015, 09:38
2015-02-21T17:42:20+01:00 2015-02-21T17:42:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=4702&p=31372#p31372 <![CDATA[problematic vst parameter resolution]]> Statistics: Posted by soundmind — 21 Feb 2015, 17:42
2015-02-14T19:09:22+01:00 2015-02-14T19:09:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=4702&p=31299#p31299 <![CDATA[problematic vst parameter resolution]]>
In usine v5 when modulating a vst parameter using the parameter array available on each vst, the modulations were instantaneous. Unfortunately in HH this is no longer the case. No matter when using the parameter pins or through the array, parameter updates happen only between a low resolution boundary (bloc?, refresh rate?). I mentioned this a long time ago and the option for instantaneous access to vst parameters was promised but it was never implemented. In its current form, it is impossible to modulate parameters with precise timing resolution. Could this possibly be solved in HH2?
Thank you for your support.
Statistics: Posted by soundmind — 14 Feb 2015, 19:09
