ArrayArrayArrayArray
BrainModularBrainModular Users Forum2015-02-14T13:09:02+01:00https://brainmodular.org/forums/app.php/feed/topic/46992015-02-14T13:09:02+01:002015-02-14T13:09:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31289#p31289Statistics: Posted by senso — 14 Feb 2015, 13:09
2015-02-13T16:39:56+01:002015-02-13T16:39:56+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31276#p31276 Creative use of scrolling ? A few I can think of:
The designer of a patch might wish the selected item not to be centered in the view but placed at the top or bottom of the view.
Or, to scroll the window to a certain position regardless of any selected item, in order to suggest an item, create a tutorial, or to automate drag and drop, which can work in list boxes (there is an option for it in the list box properties).
Or to link the scrollbar to another one, so they both move in tandem.
etc.
Simon.
Statistics: Posted by sm_jamieson — 13 Feb 2015, 16:39
]]>2015-02-13T11:58:29+01:002015-02-13T11:58:29+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31275#p31275Statistics: Posted by sephult — 13 Feb 2015, 11:58
]]>2015-02-13T11:02:04+01:002015-02-13T11:02:04+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31274#p31274 The other more specific solution would be to ensure that when a selection is made in a listbox or combobox using the selection input parameter, the selected item is brought into view. Currently in Hollyhock this does not work. I believe this used to happen in older versions of Usine.
Thanks, Simon.
Statistics: Posted by sm_jamieson — 13 Feb 2015, 11:02
]]>BrainModularBrainModular Users Forum2015-02-14T13:09:02+01:00https://brainmodular.org/forums/app.php/feed/topic/46992015-02-14T13:09:02+01:002015-02-14T13:09:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31289#p31289Statistics: Posted by senso — 14 Feb 2015, 13:09
]]>2015-02-13T16:39:56+01:002015-02-13T16:39:56+01:00https://brainmodular.org/forums/viewtopic.php?t=4699&p=31276#p31276 Creative use of scrolling ? A few I can think of:
etc.
Simon.
Thanks, Simon.
