ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2015-02-05T07:12:53+01:00 https://brainmodular.org/forums/app.php/feed/topic/4682 2015-02-05T07:12:53+01:00 2015-02-05T07:12:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31204#p31204 <![CDATA[hide container when patch is off ?]]>
-S
Statistics: Posted by sephult — 05 Feb 2015, 07:12
2015-02-05T03:29:17+01:00 2015-02-05T03:29:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31203#p31203 <![CDATA[hide container when patch is off ?]]> Statistics: Posted by gurulogic — 05 Feb 2015, 03:29
2015-02-05T03:00:39+01:00 2015-02-05T03:00:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31202#p31202 <![CDATA[hide container when patch is off ?]]>
Guru probably has the only answer regarding this, depending on how you are using...if you want to close a container when the patch disable event happens that would be the way. You could probably use the activation module to open it back up when re-enabled. I just added a change scale from 0,1 to 0,3 for Invisible/Top Parent and attached to his event button. It does hide the container when the button is pressed then disables the patch. However, you must re-enable from the patch header.
My specific case was that I did not want the top header and was building my own control menu. Unfortunately without a header once you disable...well you have to dig through the patch settings to re-enable the header then re-enable the patch...yep no thank you. I use the header.
So if you are using Guru's method though and the Grid I assume it would not work as the grid activates/deactivates the Patch enable/disable.
Thanks for the patch share guru, always interesting seeing other's approaches to these things:)
-S
Statistics: Posted by sephult — 05 Feb 2015, 03:00
2015-02-04T22:33:50+01:00 2015-02-04T22:33:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31199#p31199 <![CDATA[hide container when patch is off ?]]>
http://www.sensomusic.com/forums/upload ... active.pat
Statistics: Posted by gurulogic — 04 Feb 2015, 22:33
2015-02-04T19:26:15+01:00 2015-02-04T19:26:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31197#p31197 <![CDATA[hide container when patch is off ?]]> I don't think so, I tried once to control the patch enable and disable. If you do it from the same patch when its disabled none of you control lines will respond within the patch.
There might be a way, but I think not personally.
I was going to request a Master Control within the patch that ignores, however I think it will be to cumbersome to do.
I think it would add a whole new layer to the way the patches are handled.
-S
Statistics: Posted by sephult — 04 Feb 2015, 19:26
2015-02-04T17:42:49+01:00 2015-02-04T17:42:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=4682&p=31195#p31195 <![CDATA[hide container when patch is off ?]]>
does any one ever found an easy way to hide the container of a patch when the patch itself is inactive?
it seems so simple but I havent found a way yet
thanks in advance !
Statistics: Posted by oxyredox — 04 Feb 2015, 17:42
-S
-S
-S
thanks in advance !
