ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2015-01-30T21:44:13+02:00https://brainmodular.org/forums/app.php/feed/topic/46582015-01-30T21:44:13+02:002015-01-30T21:44:13+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31165#p31165 say you use a 8 output device at the end of your rack.
nox, if you want to use the third output with this particular rack just drop 3 audio outputs in your patch and only use the third one.
hope it helps
Statistics: Posted by oli_lab — 30 Jan 2015, 20:44
]]>2015-01-30T01:19:01+02:002015-01-30T01:19:01+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31156#p31156 I haven't really solved the matter because it is more of a question. I decided to with the default Audio outs, rather than using audio buses because I wanted to take advantage of the built in Mute & Solo controls in the Rack Settings module. I'm still interested to know if Audio outputs scope can be set to "rack", rather than "global".
]]>2015-01-25T13:48:54+02:002015-01-25T13:48:54+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31136#p31136Statistics: Posted by nay-seven — 25 Jan 2015, 12:48
2015-01-13T02:50:53+02:002015-01-13T02:50:53+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31078#p31078 Can you tell me, is the Audio 1 input the device patch global to HH? (If it is, is still have my problem.)
Statistics: Posted by sephult — 13 Jan 2015, 01:37
]]>2015-01-12T23:02:08+02:002015-01-12T23:02:08+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31076#p31076 I was in the midst of my long-winded reply on how customized devices won't work for my purposes when the solution struck me like a lightning. (Isn't it always the way?)
Thanks for providing a sounding board for my "eureka" moment.
]]>2015-01-12T15:08:05+02:002015-01-12T15:08:05+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31074#p31074 ahonoe- I once created a distribution system that was actually quite powerful, however even internally using my distribution system I found HH to best be used with the Devices, and Drag & Drop from rack to rack for IO patching. I just naturally after awhile found myself not even using my audio bus. I do not specifically have any collected data regarding CPU tax I paid for the distribution system, however when you start to get up there you start to be really conservative not to push it.
You should be able to enable all of your soundcard outputs, and in the device panel you should be able to have all of these available to your disposal to patch whatever your need. Like Nay said the pdf manual has information...If you have some creative or more detailed use let me know I will help and bounce some ideas back and forth too.
-S
Statistics: Posted by sephult — 12 Jan 2015, 14:08
]]>2015-01-12T11:18:31+02:002015-01-12T11:18:31+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31070#p31070Statistics: Posted by nay-seven — 12 Jan 2015, 10:18
]]>2015-01-12T02:37:36+02:002015-01-12T02:37:36+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31066#p31066 Thanks.
]]>BrainModularBrainModular Users Forum2015-01-30T21:44:13+02:00https://brainmodular.org/forums/app.php/feed/topic/46582015-01-30T21:44:13+02:002015-01-30T21:44:13+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31165#p31165 say you use a 8 output device at the end of your rack.
hope it helps
]]>2015-01-13T02:50:53+02:002015-01-13T02:50:53+02:00https://brainmodular.org/forums/viewtopic.php?t=4658&p=31078#p31078 Can you tell me, is the Audio 1 input the device patch global to HH? (If it is, is still have my problem.)
-S
