ArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-12-13T18:10:35+01:00 https://brainmodular.org/forums/app.php/feed/topic/4626 2014-12-13T18:10:35+01:00 2014-12-13T18:10:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=4626&p=30899#p30899 <![CDATA[VST Program Names]]>
That was the direction I started going last night, but I couldn't really understand the syntax of the IML in reference to how I was using.
Typically I phrase it like, setvalue, destination name, variable name. So when I approached I was all confused with the different variants and was totally lost at what I was doing for a bit :cool:
I will try again today with your suggestions and see what I can come up with.
Hopefully I can pull the VST names out into a script and push them back forward to a list with updates.
-S
Statistics: Posted by sephult — 13 Dec 2014, 18:10
2014-12-13T08:41:35+01:00 2014-12-13T08:41:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=4626&p=30892#p30892 <![CDATA[VST Program Names]]>
didn't found back full code but this (where LIST was the name given to my combobox, and sl1 was a tstringlist):
CODE:
Procedure U_comma;beginSendInternalMsg&#40;'SET_TARGET_PATCH','SENDER_PATCH'&#41;;sendinternalMsg&#40;'SET_STRING_VALUE','LIST','comma text',SL1.commatext&#41;;end;
so i beleive you first need to use something like 'GET_STRING_VALUE','SAMPLER','list comma text',SL1.commatext);
or maybe you can directly copy the text without first storing in internal SL1, dk, have to try..
Statistics: Posted by 23fx23 — 13 Dec 2014, 08:41
2014-12-13T05:09:07+01:00 2014-12-13T05:09:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=4626&p=30891#p30891 <![CDATA[VST Program Names]]> I think this might be my only way without getting the commatext output from a VST.
Statistics: Posted by sephult — 13 Dec 2014, 05:09
2014-12-13T04:41:33+01:00 2014-12-13T04:41:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=4626&p=30890#p30890 <![CDATA[VST Program Names]]> The only way I can seem to retrieve the latest update of Programs from the VST is to destroy the combo/list and recreate
Any other options anyone can think of?
Anyway to read back into a FastScript the list?
I am thinking a commatext output would be good to feed back into a combo or list or whatever Program Control you would like to use.
-S
Statistics: Posted by sephult — 13 Dec 2014, 04:41
-S
CODE:
-S
