ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-12-12T12:41:26+01:00 https://brainmodular.org/forums/app.php/feed/topic/4624 2014-12-12T12:41:26+01:00 2014-12-12T12:41:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=4624&p=30889#p30889 <![CDATA[Hollyhock & scpripting engine updates]]> thanks and yes cool if i can ask your advice in case :) see ya'
Statistics: Posted by 23fx23 — 12 Dec 2014, 12:41
2014-12-12T02:06:24+01:00 2014-12-12T02:06:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=4624&p=30887#p30887 <![CDATA[Hollyhock & scpripting engine updates]]>
If you need a second look or have a question let me know and I will do anything I can to help.
Always a learning process, I am constantly asking questions :)
-S
Statistics: Posted by sephult — 12 Dec 2014, 02:06
2014-12-11T19:42:42+01:00 2014-12-11T19:42:42+01:00 https://brainmodular.org/forums/viewtopic.php?t=4624&p=30883#p30883 <![CDATA[Hollyhock & scpripting engine updates]]> so I have load of anterior scripts that give me errors when i made custom procedure calls like ie if after init i put "reset_my_matrix" it return error unless i put the "reset_my-matrix" procedure before init, wich i found strange ...but maybe needed now.. seems like all called proc should be BEFORE they are actually called?
anyway will investigate,.. thx!
Statistics: Posted by 23fx23 — 11 Dec 2014, 19:42
2014-12-11T19:32:56+01:00 2014-12-11T19:32:56+01:00 https://brainmodular.org/forums/viewtopic.php?t=4624&p=30882#p30882 <![CDATA[Hollyhock & scpripting engine updates]]>
http://www.sensomusic.org/wiki2/doku.ph ... de:scripts
I just dove into HH and never really did much with previous.
Dabbling was all I did back then with Usine, then HH came along and I cant let go :)
Statistics: Posted by sephult — 11 Dec 2014, 19:32
2014-12-11T15:33:05+01:00 2014-12-11T15:33:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=4624&p=30881#p30881 <![CDATA[Hollyhock & scpripting engine updates]]>
i have severals scripts doen with 5.8 no more working with hollyock i probably just need to tweak a bit.
I was wondering if there is some place with the updates/ references notes about what has changed, what should be done..
thx
Statistics: Posted by 23fx23 — 11 Dec 2014, 15:33
-S
thx
