ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-11-18T09:32:25+01:00 https://brainmodular.org/forums/app.php/feed/topic/4601 2014-11-18T09:32:25+01:00 2014-11-18T09:32:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=4601&p=30734#p30734 <![CDATA[preset problems/ bugs]]>
Be sure to be logged , write the bug in the Issue Description window and use the submit button
Statistics: Posted by nay-seven — 18 Nov 2014, 09:32
2014-11-18T09:26:43+01:00 2014-11-18T09:26:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=4601&p=30733#p30733 <![CDATA[preset problems/ bugs]]> Statistics: Posted by Pianoscope — 18 Nov 2014, 09:26
2014-11-18T09:16:08+01:00 2014-11-18T09:16:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=4601&p=30732#p30732 <![CDATA[preset problems/ bugs]]> bug report page ? , we need more infos and the LogUsine.log files.
Statistics: Posted by nay-seven — 18 Nov 2014, 09:16
2014-11-18T00:08:11+01:00 2014-11-18T00:08:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=4601&p=30731#p30731 <![CDATA[preset problems/ bugs]]>
Is this going to be fixed?
Statistics: Posted by Pianoscope — 18 Nov 2014, 00:08
2014-11-18T00:04:36+01:00 2014-11-18T00:04:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=4601&p=30730#p30730 <![CDATA[preset problems/ bugs]]>
Made the workspace preset manager visible and saved 20 presets.
Usine then freezes on save and in the infrequent instance it does save the trace displays "Error : Internal : Finalsavedata.
No vst some au plugs. Fairly large patch with 16 racks, 8 channels of live signal processing, 10 busses. Extensive midi control.
Any suggestions? At the moment for me the workspace preset function is broken.
macbook pro 2.5ghz 16gig ram
Statistics: Posted by Pianoscope — 18 Nov 2014, 00:04
