Statistics: Posted by pumeus864 — 31 Dec 2014, 09:17
]]>2014-10-31T21:31:38+01:002014-10-31T21:31:38+01:00https://brainmodular.org/forums/viewtopic.php?t=4584&p=30660#p30660Statistics: Posted by caco — 31 Oct 2014, 21:31
2014-10-31T17:24:02+01:002014-10-31T17:24:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4584&p=30657#p30657Statistics: Posted by ceasless — 31 Oct 2014, 17:24
]]>2014-10-29T12:49:25+01:002014-10-29T12:49:25+01:00https://brainmodular.org/forums/viewtopic.php?t=4584&p=30655#p30655 http://www.mixcloud.com/ctrpt/ark-hd-li ... ason-edit/
here is a screenshot of main drums rack. As drummachines it uses two D16 nephetons and two D16 drumazons (so two 808, a 909 drummachines)
they are feeded by different pianorolls that two matrices on the bottom solves the routing from pianorolls to drummachines.
upper matrices are routing different outputs from the drum machines to effects (for each matrix there is one "ghost" matrix which takes array otuput to array input to solve stereo) and after that you can feed one effect to another one, to make glitchy processed sounds.
]]>2014-10-31T17:24:02+01:002014-10-31T17:24:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4584&p=30657#p30657Statistics: Posted by ceasless — 31 Oct 2014, 17:24
