ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-10-11T17:37:26+01:00 https://brainmodular.org/forums/app.php/feed/topic/4572 2014-10-11T17:37:26+01:00 2014-10-11T17:37:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30586#p30586 <![CDATA[Smooth freeze clic]]> Statistics: Posted by joffo78 — 11 Oct 2014, 18:37
2014-10-11T17:32:28+01:00 2014-10-11T17:32:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30585#p30585 <![CDATA[Smooth freeze clic]]> initially this patch is a polyphonic patch and try to reproduce a piano damper pedal system.
So when you activate send switch all the time the hold switch has the same utility than a piano pedal.
Statistics: Posted by joffo78 — 11 Oct 2014, 18:32
2014-10-11T15:30:55+01:00 2014-10-11T15:30:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30583#p30583 <![CDATA[Smooth freeze clic]]> There is 4 options for the sound detection: env follower, beat follower, frequency change and Off. If i set it to Off the freeze sample never stop nor change.
Is it ok ?
Statistics: Posted by cmodica — 11 Oct 2014, 16:30
2014-10-11T15:10:08+01:00 2014-10-11T15:10:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30582#p30582 <![CDATA[Smooth freeze clic]]>
But if i mute the input it keeps the sample and never stop ...
Is it true or is it a bug ?
Statistics: Posted by cmodica — 11 Oct 2014, 16:10
2014-10-11T14:42:58+01:00 2014-10-11T14:42:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30581#p30581 <![CDATA[Smooth freeze clic]]>
Congratulation, you are a master !!!!
We have a rehearsal on monday and i will test it in live condition.
Thank you very much !!!!!:lol:
I will take a look later to this patch and try to understand.
i will tell you about my experience in live. Thank you very very much.
Statistics: Posted by cmodica — 11 Oct 2014, 15:42
2014-10-10T18:24:45+01:00 2014-10-10T18:24:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30580#p30580 <![CDATA[Smooth freeze clic]]> http://www.sensomusic.com/forums/upload ... freeze.pat
Statistics: Posted by joffo78 — 10 Oct 2014, 19:24
2014-10-10T15:04:49+01:00 2014-10-10T15:04:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=4572&p=30579#p30579 <![CDATA[Smooth freeze clic]]>
it works well but there is a clik when the sound loop ... The sound is 350 ms long, so there is a lot of clik !
Is there a way to do that without this clik ?
thanks.
Statistics: Posted by cmodica — 10 Oct 2014, 16:04
Is it ok ?
thanks.
