ArrayArrayArrayArray
BrainModularBrainModular Users Forum2014-10-10T01:51:02+01:00https://brainmodular.org/forums/app.php/feed/topic/45712014-10-10T01:51:02+01:002014-10-10T01:51:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30578#p30578Statistics: Posted by shawnb — 10 Oct 2014, 02:51
2014-10-09T08:46:11+01:002014-10-09T08:46:11+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30576#p30576 However the triggers are generated by audio via an envelope generator For a stream of percussive hits I want to generate a trigger say for every 7th hit
Statistics: Posted by Pianoscope — 09 Oct 2014, 09:46
]]>2014-10-09T02:28:25+01:002014-10-09T02:28:25+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30575#p30575 I'd be tempted to do it at the source, via math, where you generate the trigger. For example - count the triggers using a counter, then only "Pass" if (Count MOD X) = 0, where X = 9 or 13 in your example.
I use a clock-based filter on my add-on "CC Generator". You can "thin the herd" of CCs generated by adjusting the clock interval. You can take a peek for an approach there.
]]>2014-10-08T14:10:30+01:002014-10-08T14:10:30+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30571#p30571 I then want to filter them out, changing the "density" only allowing say one in every nine triggers, or one every thirteen through to the next stage of the patch.
Perhaps there could be a general density control that would allow more or less through.
I am not sure how to proceed with filtering x amount of the triggers out.
A density defined random trigger filter ...?
Statistics: Posted by Pianoscope — 08 Oct 2014, 15:10
]]>BrainModularBrainModular Users Forum2014-10-10T01:51:02+01:00https://brainmodular.org/forums/app.php/feed/topic/45712014-10-10T01:51:02+01:002014-10-10T01:51:02+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30578#p30578Statistics: Posted by shawnb — 10 Oct 2014, 02:51
]]>2014-10-09T08:46:11+01:002014-10-09T08:46:11+01:00https://brainmodular.org/forums/viewtopic.php?t=4571&p=30576#p30576 However the triggers are generated by audio via an envelope generator For a stream of percussive hits I want to generate a trigger say for every 7th hit
