ArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-09-13T19:54:04+01:00 https://brainmodular.org/forums/app.php/feed/topic/4523 2014-09-13T19:54:04+01:00 2014-09-13T19:54:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=4523&p=30451#p30451 <![CDATA[FTP GMS Switch]]> Play is much more dynamic, organic & fluid than any other guitar MIDI controller I've played.
It's the only guitar MIDI controller that feels truly expressive & doesn't require you to change your technique to work properly.
It's NOT perfect. There are still occasional glitches. But they are very rare.
Regarding this patch, I should add one hint for those who use it:
You really need to select your GUITAR processing patch before selecting your SYNTH processing patch. This is so the current FTP patch & settings are in the state required for the SYNTH patch.
Statistics: Posted by shawnb — 13 Sep 2014, 20:54
2014-09-01T18:00:16+01:00 2014-09-01T18:00:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=4523&p=30400#p30400 <![CDATA[FTP GMS Switch]]> Statistics: Posted by sephult — 01 Sep 2014, 19:00
2014-08-27T09:08:13+01:00 2014-08-27T09:08:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=4523&p=30357#p30357 <![CDATA[FTP GMS Switch]]>
now we're waiting for a video demonstrating how you use this ;-)
Statistics: Posted by nay-seven — 27 Aug 2014, 10:08
2014-08-20T06:26:14+01:00 2014-08-20T06:26:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=4523&p=30289#p30289 <![CDATA[FTP GMS Switch]]>
This helps you use the Guitar-Mix-Synth Switch on the FTP meaningfully within Usine HH.
Screenshots of how the patch may be used, and one possible workspace configuration are below.
LOTS of real-world helpful information for FTP users may be found here, over at vguitarforums.com:
http://www.vguitarforums.com/smf/index.php#c19
Promo material on the FTP:
http://www.fishman.com/tripleplay
Shawn
Statistics: Posted by shawnb — 20 Aug 2014, 07:26
Shawn
