ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2014-08-28T13:35:55+02:00https://brainmodular.org/forums/app.php/feed/topic/44982014-08-28T13:35:55+02:002014-08-28T13:35:55+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30368#p30368 Furthermore he explains, if the sequencers are running for example with 44100 hz and a buffer size of 512, the signal needs 512 Samples (ca. 0.01 ms) to arrive at the receiver.
Is this information sufficient? (I hope I translate it correct)
Statistics: Posted by magickz — 28 Aug 2014, 13:35
]]>2014-08-26T18:44:52+02:002014-08-26T18:44:52+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30354#p30354 Edit, 28. August 2014: After my first tests I am just amazed about this thing...
Just for fun I used it to connect two Usine instances (one 64 bit and one 32 bit version) together with another DAW, all running on the same PC. Assumed that it has a low latency such as theVSTforx (described in the next post below) and does not kill my CPU to run so many daws at the same time, I think this is the easiest and most elegant solution that I found so far. Makes it possible to connect multiple racks in two systems with several tracks in the other DAW into all possible directions within 10 seconds And the best is in my opinion that it integrates multiple audio streamsanda midi stream at the same time (no need for Loopbe or something similar). You just load it as a plugin, without the necessity to configure some midi port or something in the Usine software configuration. It can be used in networks as well (by connecting to an IP address). But I use it just on "localhost". For me there is no audible latency, but I am still waiting for a concrete technical information from the Reaper community (will report further insights here)...
In Usine it looks like this:
Sender and receiver must have a matching unique identifier.
The output parameter "latency" seems to constantly ouput "0.00000 samples" today - I have no idea about it's function.
:rolleyes: I guess one could even use this along with two Usine instances (for example 32 and 64 bit) to have two interface builders available and of course the advantage of using 64 bit and 32 bit plugins the same time without leaving Usine.
Statistics: Posted by magickz — 26 Aug 2014, 18:44
]]>2014-08-20T01:18:07+02:002014-08-20T01:18:07+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30285#p30285 +1 for Beardyman. I've watched him for a few years now (well, since his 'mixing' youtube video). Fricking awesome. Seen him live once, but it was poor unfortunately due to enforced low volume levels. His work methods are a very big influence on the building of my current setup. It's kinda like his, but with Leap Motion Control, edrum kit, guitar, and bass (but with less iPads and beatboxing skills). I've really gotta get some examples up for you guys!!! Hehe, I love doing the 'silly hi voice loopy song' type thing, which Beardyman surely must have invented.
I began setting up Mobius again. Hopefully I'll have more luck this time. :/
]]>2014-08-18T22:09:09+02:002014-08-18T22:09:09+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30257#p30257 Hey Loopy. I am sorry, I have no experience at all... and now I read about the clicking and synching for the first time. I thought the Mobius documentation looks so complex. Maybe out of my laziness I should use Regen to get a first idea about the technique of looping.
Very Cool. Initially I only wanted to learn the piano or something... But it seems a few months later after the intial idea I will know all about programming synths, sampling and production tools, EQing and compressing and such things, and still nothing about making music... maybe I should finally start learning to play an instrument or to sing to have something to loop But then again meeting Usine, I believe it would be more fun to build an own instrument with it and learn to play it before I learn from the theory why it sounds good or bad Let's see...
Yes, I agree Mr. Beardyman is just brilliant. I have seen something from him just a few weeks before when I was just surfing for something about looping. And I just watched another video of him, now focussing more on his setup. And it seems to be very user friendly and seems to provide a good overview with so many touch screens involved. He is really an admirable artist. And I love his humor
Statistics: Posted by magickz — 18 Aug 2014, 22:09
]]>2014-08-18T11:02:09+02:002014-08-18T11:02:09+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30252#p30252Statistics: Posted by seamus — 18 Aug 2014, 11:02
Now I am really in trouble... I would like to use the 32 bit version, but some plugins are just not available for 32 bit, others are not available in 64 bit... Time to reorganize again for a second time, before I can start playing...
Statistics: Posted by magickz — 18 Aug 2014, 06:42
Statistics: Posted by magickz — 18 Aug 2014, 06:36
]]>2014-08-17T16:01:28+02:002014-08-17T16:01:28+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30244#p30244Statistics: Posted by seamus — 17 Aug 2014, 16:01
]]>2014-08-17T15:49:03+02:002014-08-17T15:49:03+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30242#p30242Statistics: Posted by seamus — 17 Aug 2014, 15:49
]]>2014-08-12T10:40:03+02:002014-08-12T10:40:03+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30211#p30211Statistics: Posted by seamus — 12 Aug 2014, 10:40
]]>2014-08-12T04:20:30+02:002014-08-12T04:20:30+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30210#p30210
They're just modded RC-51s. The loop type selectors don't really work. And I really need a pan pot on each slot. And a good hold of each waveform's set of markers, and their positions. And it lacking solidity. And they need some more of their juice back..... three quarters into it, I went touchscreen, so they went a bit 'Transformery', due to BIG mutes and gains. A little more 'Usine Pro' than 'HH'.
]]>2014-08-10T17:34:59+02:002014-08-10T17:34:59+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30192#p30192Statistics: Posted by seamus — 10 Aug 2014, 17:34
]]>2014-08-10T11:04:02+02:002014-08-10T11:04:02+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30191#p30191 J-Bridge was/is satisfactory for myself, but there is that UI glitch. Ohhhhh if I remember correctly.... Reaper handles the .fxp files well. Mmmm.... Didn't think I'd ever use Reaper again, but I'm dying to mess with some python/JS stuff, and more, with these new found eyes. Cheers magickz!
Shit, and that reminds me seamus... should probably give mobius another shot. I get the impression Mobius is looper-king. Is it? Well after the Juicy Duo at least.....
I have found some other plugins with some interface issues. For example there is a great addon by Graywolf, developer of BlueArp, that allows me to control every aspect of my Nova hardware synthesizer ( http://www.graywolf2004.net/my-projects ... ntrol-vst/ ), and save my patches for later reuse on my PC. It is made with Synthmaker. And it seems not to be able to turn the knobs in the interface. But, basically it works if I create my own knobs in a patch that replaces all the builtin knobs. But, to be honest, I am too lazy to recreate an already good interface with hundreds of knobs and buttons. And I do not understand how to trigger the dialogue for saving and loading those patches created in the Nova Control VST. I wouldn't agree with other users who think that generally all Synthmaker or all Synthedit or Whatever plugins are not good, as some of them provide exactly the functionality that I need, and that you cannot find somewhere else.
That is why I am still looking at solutions like virtual midi cables, ReWire, and this one above. Usine is almost perfect, and I guess Usine paired with a robust host that can bridge and handle everything will be my dream team. I just worry about CPU and memory resources on my PC.
Statistics: Posted by magickz — 09 Aug 2014, 08:16
]]>2014-08-05T22:36:59+02:002014-08-05T22:36:59+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30162#p30162I noticed I do not have these problems with ableton
]]>2014-08-05T22:00:17+02:002014-08-05T22:00:17+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30161#p30161Statistics: Posted by magickz — 05 Aug 2014, 22:00
]]>2014-08-05T21:29:00+02:002014-08-05T21:29:00+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30160#p30160
Statistics: Posted by magickz — 05 Aug 2014, 21:29
]]>2014-08-05T20:54:41+02:002014-08-05T20:54:41+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30159#p30159Statistics: Posted by caco — 05 Aug 2014, 20:54
]]>2014-08-05T12:11:31+02:002014-08-05T12:11:31+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30150#p30150 If you are interested, try this:
1. In Usine I load the Remote Channel Sender plugin from VSTforx into the rack that I want to manipulate (for example with a 32 bit filter plugin).
2. In Reaper I load the VSTforx plugin and assign the Remote Channel Receiver to it's output. In the same chain I add my filter plugin. The third plugin in this chain is another Remote Channel Sender plugin.
3. Back in Usine I need another VSTforx plugin to receive the Remote Channel from Reaper and redirect it to the rack output.
4. Now, in Reaper the master volume can be muted. The sound is now being generated in Usine, filtered in Reaper and sent from Usine to the connected audio interface.
Statistics: Posted by magickz — 05 Aug 2014, 12:11
]]>BrainModularBrainModular Users Forum2014-08-28T13:35:55+02:00https://brainmodular.org/forums/app.php/feed/topic/44982014-08-28T13:35:55+02:002014-08-28T13:35:55+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30368#p30368 Furthermore he explains, if the sequencers are running for example with 44100 hz and a buffer size of 512, the signal needs 512 Samples (ca. 0.01 ms) to arrive at the receiver.
]]>2014-08-18T06:42:47+02:002014-08-18T06:42:47+02:00https://brainmodular.org/forums/viewtopic.php?t=4498&p=30251#p30251 http://www.z3-audiolabs.com/repeat-x/
