ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2014-07-06T09:12:24+01:00 https://brainmodular.org/forums/app.php/feed/topic/4456 2014-07-06T09:12:24+01:00 2014-07-06T09:12:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29886#p29886 <![CDATA[Matrix>Array values in preset manager]]> Statistics: Posted by joffo78 — 06 Jul 2014, 10:12
2014-07-06T08:38:36+01:00 2014-07-06T08:38:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29884#p29884 <![CDATA[Matrix>Array values in preset manager]]> Statistics: Posted by gurulogic — 06 Jul 2014, 09:38
2014-07-06T07:19:39+01:00 2014-07-06T07:19:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29883#p29883 <![CDATA[Matrix>Array values in preset manager]]> It mean if you recall a mem and modify it only the cells modifiy are stored. It's a problem. Need to speak about senso team.
Statistics: Posted by joffo78 — 06 Jul 2014, 08:19
2014-07-06T07:05:58+01:00 2014-07-06T07:05:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29882#p29882 <![CDATA[Matrix>Array values in preset manager]]>
in this example
You can easily store matrix settings, preview there and load on by pressing GET button.
Hope it can help you
Statistics: Posted by joffo78 — 06 Jul 2014, 08:05
2014-07-05T22:52:59+01:00 2014-07-05T22:52:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29881#p29881 <![CDATA[Matrix>Array values in preset manager]]>
Wish I could have sorted out this problem, seems it should be simple enough but at this point it is probably faster to repatch my workspace with the routing Matrixes put in the main patches. Thanks for the help tho. Apparently I'm taking this setup out for a live performance next weekend and I have till Tuesday eve to prep! hahahaaa... see how that goes. Might have bit off a bit more than I can chew :|
Statistics: Posted by gurulogic — 05 Jul 2014, 23:52
2014-07-05T11:11:59+01:00 2014-07-05T11:11:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29880#p29880 <![CDATA[Matrix>Array values in preset manager]]> About the preset manager in rack 2, I have reasons. It's hard to explain but just to say, rack 2 ultimately has 16 patches x 16 presets and I want to be able to load or unload each of these 16 patches at will with different versions and mix settings without having any dependencies from rack 1. rack 1 is intended only for "slave" routing purposes from my audio interface.
I'm not so worried about why the example I uploaded isn't working quite right as I am about how to properly relay data from the audio matrixes to the get/set array to store as presets within the preset manager and send back to the audio routing matrix via preset recall without weird feedback issues, which is what seems to be happening.
Statistics: Posted by gurulogic — 05 Jul 2014, 12:11
2014-07-05T10:32:17+01:00 2014-07-05T10:32:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29879#p29879 <![CDATA[Matrix>Array values in preset manager]]> the list button module which drive the preset manager is set to saved in preset, this can create confusion.
why do you need the preset manager in another rack..? the process will be more simpler if it you put him in rack 1 and drive it eventually by bus from rack 2, no...?
Statistics: Posted by nay-seven — 05 Jul 2014, 11:32
2014-07-05T10:06:14+01:00 2014-07-05T10:06:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29878#p29878 <![CDATA[Matrix>Array values in preset manager]]>
http://www.sensomusic.com/forums/upload ... preset.wkp
Statistics: Posted by gurulogic — 05 Jul 2014, 11:06
2014-07-05T08:25:32+01:00 2014-07-05T08:25:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29877#p29877 <![CDATA[Matrix>Array values in preset manager]]> Any chance for a simple example workspace to illustrate your needs...?
Statistics: Posted by nay-seven — 05 Jul 2014, 09:25
2014-07-05T08:13:03+01:00 2014-07-05T08:13:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=4456&p=29876#p29876 <![CDATA[Matrix>Array values in preset manager]]> Problem is, is that no matter what combination of modules and approaches I try, I get inconsistent accuracy for the stored values being sent from a get/set array to the audio matrix array inlet. Sometimes I need to toggle presets back and forth several times to get the values updating properly, sometimes the data sent to the audio matrix seems to get mixed between two or more presets. I'm thinking I may be encountering a bug of some sort, but maybe there is something I'm missing?
Here is one of many attempts. Yes this patch has a stop and pass sequentially in the same wire, just trying everything I can think of to stop inconsistent values being sent to the matrix. Even the most logical approaches don't seem to work right but I would be very happy if someone could prove me wrong. I have already spent far too much time trying to work out a solution for this. (btw, no problem directly sending get/set array values stored in a preset to the audio matrix so this rules out issues with actually storing and recalling the values)
Here is one that seems a lot simpler, that should also work?
Statistics: Posted by gurulogic — 05 Jul 2014, 09:13
in this example
